jd 316 onan not charging
   / jd 316 onan not charging #11
My JD 316 started showing the battery light. I replaced the battery, stator, and voltage regulator and still am getting the battery light. Any suggestions?
   / jd 316 onan not charging #12
Do you have a good multimeter to test with?
   / jd 316 onan not charging #13
Yes. I tested the output of the stator...37 volts AC
I tested the output of the voltage regulator by leaving the stator connected and removing the center plug on the VR. It showed a -2.5 DC I then put
the old VR back in the tractor and tested it. I showed a + 2.0 I tested the plug that connects to the VR and the voltage was +12.5 Also, when I
reconnect the center plug to the VR and test it, it shows +12.5 I'm thinking I my have gotten a bad VR
Aluma 7712H Tilt Trailer (A50514)
Aluma 7712H Tilt...
2021 Chevrolet Silverado Pickup Truck (A51039)
2021 Chevrolet...
2016 KLEEMAN MS192 MOBILE SCREEN (A51242)
2016 KLEEMAN MS192...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
2004 TAKEUCHI TB175 EXCAVATOR (A51242)
2004 TAKEUCHI...
LOT LOCATIONS (A51219)
