jd 316 onan not charging
   / jd 316 onan not charging #11
My JD 316 started showing the battery light. I replaced the battery, stator, and voltage regulator and still am getting the battery light. Any suggestions?
   / jd 316 onan not charging #12
Do you have a good multimeter to test with?
   / jd 316 onan not charging #13
Yes. I tested the output of the stator...37 volts AC
I tested the output of the voltage regulator by leaving the stator connected and removing the center plug on the VR. It showed a -2.5 DC I then put
the old VR back in the tractor and tested it. I showed a + 2.0 I tested the plug that connects to the VR and the voltage was +12.5 Also, when I
reconnect the center plug to the VR and test it, it shows +12.5 I'm thinking I my have gotten a bad VR
1275 (A50490)
1275 (A50490)
Stage Line Trailer (A50322)
Stage Line Trailer...
Bad Boy Outlaw XP61 Zero Turn Mower (A48082)
Bad Boy Outlaw...
500 gal Fuel Barrel with Pump (A50515)
500 gal Fuel...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2019 Bobcat E32i Mini Excavator (A50322)
2019 Bobcat E32i...
