jd 316 onan not charging
   / jd 316 onan not charging #11
My JD 316 started showing the battery light. I replaced the battery, stator, and voltage regulator and still am getting the battery light. Any suggestions?
   / jd 316 onan not charging #12
Do you have a good multimeter to test with?
   / jd 316 onan not charging #13
Yes. I tested the output of the stator...37 volts AC
I tested the output of the voltage regulator by leaving the stator connected and removing the center plug on the VR. It showed a -2.5 DC I then put
the old VR back in the tractor and tested it. I showed a + 2.0 I tested the plug that connects to the VR and the voltage was +12.5 Also, when I
reconnect the center plug to the VR and test it, it shows +12.5 I'm thinking I my have gotten a bad VR
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A51572)
IMPORTANT PLEASE...
Brent 420 Grain Cart (A50514)
Brent 420 Grain...
1994 Chevy  2500 Dually Pick Up Truck (A50515)
1994 Chevy 2500...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2013 FORD F-450 UTILITY TRUCK (A51222)
2013 FORD F-450...
2015 JCB 930 6,000LB 4x4 Rough Terrain Forklift (A50322)
2015 JCB 930...
