jd 316 onan not charging
   / jd 316 onan not charging #11
My JD 316 started showing the battery light. I replaced the battery, stator, and voltage regulator and still am getting the battery light. Any suggestions?
   / jd 316 onan not charging #12
Do you have a good multimeter to test with?
   / jd 316 onan not charging #13
Yes. I tested the output of the stator...37 volts AC
I tested the output of the voltage regulator by leaving the stator connected and removing the center plug on the VR. It showed a -2.5 DC I then put
the old VR back in the tractor and tested it. I showed a + 2.0 I tested the plug that connects to the VR and the voltage was +12.5 Also, when I
reconnect the center plug to the VR and test it, it shows +12.5 I'm thinking I my have gotten a bad VR
Quick Attach Pallet Forks (A47384)
Quick Attach...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
Woods BW12 Batwing Mower (A50514)
Woods BW12 Batwing...
2024 Case IH Magnum 380AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
2014 Chevrolet Spark Hatchback (A50324)
2014 Chevrolet...
19011 (A48082)
19011 (A48082)
