JD 3038E Hydraulic problem
   / JD 3038E Hydraulic problem #1
mfaulk
richland, tx
I have a John Deere 3038E that is about 6 years old, 400 hrs. The loader works fine. The problem is with the hitch. As I adjust the rockshaft lever from the 1 position to a higher number, nothing happens until I reach about 6. The hitch then raises all the way up, unless I pull back on the lever just a little, then the hitch will stop at the position it has reached. It appears to hold that position until I move the lever again slightly. If I move the lever slightly lower, the hitch goes all the way down, and if I move the lever slightly higher, the hitch goes all the way up. This problem appeared after a few months of not using the hitch. Thanks for any help.
   / JD 3038E Hydraulic problem #2
My 3038e just started doing the same thing today. Did you figure out what was wrong or how to fix?
2017 International DuraStar 4300 Cab and Chassis Truck, VIN # 1HTMMMML9HH471713 (A57453)
2017 International...
FENCE PANELS (A58214)
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
New/Unused CFG Industrial H12R Mini Excavator (A57453)
New/Unused CFG...
Push Mower (A59231)
Push Mower (A59231)
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
