JD 3038E Hydraulic problem
/ JD 3038E Hydraulic problem #1
mfaulk
richland, tx
I have a John Deere 3038E that is about 6 years old, 400 hrs. The loader works fine. The problem is with the hitch. As I adjust the rockshaft lever from the 1 position to a higher number, nothing happens until I reach about 6. The hitch then raises all the way up, unless I pull back on the lever just a little, then the hitch will stop at the position it has reached. It appears to hold that position until I move the lever again slightly. If I move the lever slightly lower, the hitch goes all the way down, and if I move the lever slightly higher, the hitch goes all the way up. This problem appeared after a few months of not using the hitch. Thanks for any help.
/ JD 3038E Hydraulic problem #2
My 3038e just started doing the same thing today. Did you figure out what was wrong or how to fix?
2022 CATERPILLAR 289D3 SKID STEER (A65053)
2022 CATERPILLAR...
KUBOTA B3300SU TRACTOR (A64280)
KUBOTA B3300SU...
72" JCT TILLER (A62613)
72" JCT TILLER...
2016 KUBOTA RTV-X900 UTV (A64280)
2016 KUBOTA...
2020 Deere 50G (A64119)
2020 Deere 50G...
2017 Caterpillar 349FL Hydraulic Excavator (A61572)
2017 Caterpillar...
