JD 2520 ROPS pin alignment
   / JD 2520 ROPS pin alignment #1
topstoy
Tonasket, WA
JD 2520 / Kubota KX121-3
Recently purchased a new 2520. One issue that I have with it is that the removable pins to fold the ROPS down are so miss aligned that there is no way to put both sides back in. My local dealer has tried and couldn't get them in either. I had to drive the first one out with a punch and once out you could see that the alignment was way off. My dealer said that there is a JD service notice about this and that they are waiting on a response from JD. Has anyone else had this problem and if so how long did it take to resolve? Did they end up installing a new ROPS or did they do something to the existing ROPS to correct this? Thanks, Ken
   / JD 2520 ROPS pin alignment #2
everyone has same prob i filled mine out then i changed pin put one in with handle from tsc 4 more leverage still a little tite but works better.
   / JD 2520 ROPS pin alignment #3
My 2520 is a early build, and my Rops pins go in with no effort at all. They allign perfectly, and are very easy to put back in. They drop in, requiring no pushing at all.
   / JD 2520 ROPS pin alignment #4
Maybe not everyone but I also had the problem. I reamed out the holes.
   / JD 2520 ROPS pin alignment #5
A round file worked wonders on my 3320.
   / JD 2520 ROPS pin alignment #6
I bought my 2520 new. I can see where my ROPS pins were hit with a hammer a few times, however, they go in and out easily. Therefore, I assume that the dealer reamed out the holes a little before delivering it.
   / JD 2520 ROPS pin alignment #7
I had the same problem on my 5103 and JD put one pin in it and drilled the other side out so it would line up. Works good now, they both slide in and out easily..... Bull
Thanks for the responses, I will likely end up fileing or drilling out. Just giving the dealer a chance to do something first. Seems to me that when you chose a JD, you are paying top dollar for well engineered eqipment and items such as this should be checked and corrected before it is sold to a customer. :confused:
   / JD 2520 ROPS pin alignment #9
There is another way...
Had the same problem with my 2520 when I bought it.
When I told my salesman about it, he was pretty upset saying that this is supposed to be checked before the machine leaves.
The service dept tech loosened all the ROPS bolts at the fenders, then moved/twisted the ROPS around until the pins worked easily - then re-tightened/torqued.
The dealer tried that trick of loosing the ROPS from the frame but they couldn't get it to move enough to make it line up. The holes for the pin are about 1/4" off from lining up.
2015 Acura MDX SUV (A50324)
2015 Acura MDX SUV...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A48081)
2015 Ford F-550...
2004 Ford F250 (A50515)
2004 Ford F250...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
E-Z Trail 672 Head Cart (A50514)
E-Z Trail 672 Head...
