JD 2440
/ JD 2440 #1
muleman54
Cusseta Al
Ford 2000 Farm Pro 2420
Purchased today by my Son in law. how can we add rear auxiliary remotes to this tractor?
Thanks
Muleman 54
/ JD 2440 #2
:welcome:to TBN
You can purchase a used scv assembly from a salvage yard or install a spool control valve similar to frt end loader control valve. Valve similar to FEL can be attached to fender or mounted on a stand bolted to rear axle. IF aftermarket spool valve be sure valve has closed-center plug installed. Photo below is how to attach FEL type spool valve.
/ JD 2440
Thanks Tx Jim,
I do have one more question, to connect the spool valve is it connected directly to the hydraulic pump? His has a round pump with several plugs around the circumference. How would we determine which is a pressure flow and which is a return?
Doug
/ JD 2440 #4
Evidently you did not look at the photo I posted!!!!! For pressure one needs to attach line to rear of pressure control valve on RH side very close to hyd filter at fitting(parts key 4). Then return oil goes to either trans case or better yet a hyd filter ported cover.
/ JD 2440
I did look but unfamiliar with these JDs I was unsure of the items that were not labeled.
Doug
/ JD 2440 #6
Sorry I suppose I should have explained 1st photo in more detail. After being around these tractors since they were new I forget some folks are not as familiar with them as others.
Jim
Caterpillar 931/953/953C/963/963C Parts and Service Manuals (A63117)
Caterpillar...
2023 73in Hydraulic Roller Skid Steer Attachment (A61572)
2023 73in...
2019 KUBOTA SVL95-2S SKID STEER (A64279)
2019 KUBOTA...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
2022 Tesla Model 3 Long Range AWD Sedan (A61574)
2022 Tesla Model 3...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A63689)
Dual Tailwheel...
