Snow Jd 2320
/ Jd 2320 #1
Sven_SITE
JD 2320
i have a 2320 and am preparing for the storm that we are going to be getting in the north east tomorrow. I have a 200cx loader and jd backhoe attachment. I was planning to remove the backhoe tonight because the outriggers prohibit me from getting close enough to building edges but if i have solid filled jd tires do i need to put ballast box on or will tires be sufficient weight for pushing and moving snow? Really wish i boug the quick hitch attachement for ballast box because the 3pt is a pain. Any thoughts or ideas? Am i better off leaving backhoe on and watching my sides?
/ Jd 2320 #2
My laziness says, leave the hoe on and mind the sides. It would give you extra weight and might come in handy if you get stuck. But I don't know the challenges you face with building clearances.
/ Jd 2320 #3
What type of tires? Turf or industial? I've heard the latter is useless in snow and I know from experience the turfs aren't much use in snow. Filled tires should be enough weight for snow. Chains would boost traction more than weight.
/ Jd 2320
Thanks. Leaning in this direction too. Its been soo long since we got a good snow but i think thats what i did last time too probably due to laziness.
/ Jd 2320
Industrial tires and theyve actually been pretty good in the past so hopefully they will be good this time too. It may be obvious but i found that Its all about keeping momentum. Chains would be a good idea. Maybe next time.
/ Jd 2320 #6
On my 2520, I have a set of unfilled turfs, and a set of loaded industrials. The turfs are tons better in snow for me.. Advantage of a 2520 or even a 2320 are the larger tires vs say a 2210/2305.
/ Jd 2320 #7
BTW, I have a B2620 Kubota, maybe similar to your 2320? Regardless, I have loaded industrial tires and 4wd. I would have preferred turfs, but bought this used. I find that the loaded tires are ok and I run a backblade and loader most of the time. Obviously, the small blade doesn't add much weight.
Fels aren't the best for snow removal but you gotta use what you got. Next year you may want to add rear chains and a back blade.
/ Jd 2320 #8
I have the 2520 with the Hoe on the back and the Industrial R4 tires. I leave the Hoe on for weight and just be mineful of it being back there. Everyone says that the R4's are worthless in the snow. Well they may not be great but for the most part they work ok. Only once in a while do I start spinning and it is typically when the snw starts warming up to that slippery state or when the old snow underneath is a sheet of ice. But for the most part it works well for me even with my hills. Best of luck to you with the storm.
/ Jd 2320 #9
I had a bx25 and plowed with the BH on as the extra weight makes a huge difference. I left the BH for mowing the lawn as I found the process of removing the 3pt such a PITA....
My 2320 has a rear blower which I should be giving a good workout soon....
BTW, the BH makes an amazing ditch tractor extractor....... I once plowed into the ditch and was completely stuck. BH to the rescue as without it I would have had to get someone to pull me out.
/ Jd 2320 #10
I think you're OK if it's level. I've got a 2320, unloaded R4s and I often clear with the loader. I usually have either a box blade or a snowblower on the back. You can spin it out but by that time, the loader has piled up so much snow you need to dump it anyway.
/ Jd 2320 #11
Sven
Momentum is your friend. I have loaded R4s and find they do pretty well as long as I keep the momentum up. I can push snow for more than one hundred feet before I have so much snow piled up in front I lose momentum and have to move it to the side to dump. Of course on ice it is much less. When I push a lot of snow and the tires are on ice the rear of the tractor really wants to go sideways. My driveway goes up a gentle hill and while I can tell it is there the tractor keeps on going. Usually I have a rear blade on but sometimes if it is near freezing a rake works better to bring some of my gravel to the surface. Good luck during the storm, it sounds like a doozy.
/ Jd 2320 #12
i think you may have accidently worded this wrong. Industrials have no traction in snow. Turfs are superior. Industrials have no grip whatsoever. I suppose if you ran around in 12 inches of snow with the blade in the air they would be superior but once you put the blade down and remove the snow and are stuck with a thin film ofsnow, you lose all traction like drag racing slicks in the rain. at that point turfs reign supreme
/ Jd 2320 #13
I though he had it right, but then again I'm french. :confused3:
/ Jd 2320 #14
Saying R4's have no traction in snow is not correct either. I agree that Turfs are a better choice, but I have R4's that are not loaded and have a very steep driveway and manage just fine. If they had no traction, I would not be able to deal with my 800 ft long very steep driveway. Would I prefer turfs? Yes! But I don't have turfs and it is not bad enough for me to go and spend the $1K or so on getting them. Maybe when I start mowing this will change....
On ice, the R4's have very little traction but to be honest the only tire that will be good on ice is a tire with a chain on it...
/ Jd 2320 #15
I agree with Mac as my driveway is about 1000 feet and most of it uphill and managed just fine pushing 8" of snow with my FEL using the R4's. Apparently there are some folks on here that have very little experiance and making big claims.
/ Jd 2320 #16
Well, we'be all chimed in, and the storm has come and gone. How did it go for you, Sven?
/ Jd 2320 #17
. your right, i dont know what im talking about becuase it doesnt snow upstate new york. Sorry I hurt your feelings about your r4 tire
/ Jd 2320 #18
I have both turf and R4s. Sorry but turfs seem much much better to me in snow. I would change over if it wasn't for the fear of having the opposite problem tilling in the summer. I spend way more time tilling then I do snow blowing. I have about 600hr total recent operating time to make that claim.
/ Jd 2320 #19
I have a 2720 with R4. I just went though the 2013 Blizzard in CT. Where I live on top of a hill. I got over 4 feet of snow and drifts over 7 feet high. The R4 in 4wd worked fine. I have a ballst box onthe rear with 350lbs. Just enought to conter the weight of the 54' blower. I had one issue on Sunday when I went to far in bottwm of a 6 foot pack snow bank that the street plow left infront of a driveway. The bank fell between the tractor and blower. I tried to back up but the weight of the snow burying the front was to much. I was also on a layer of ice. Dug out the snow between the blower and the tractor and it backed out without any issues. I was a little more careful after that. I do have chains, but in 3 years i have never had to use them.
/ Jd 2320 #20
Here is a picture of my 2720. I working on making the cab myself. The front, roof and back are done. still working one the doors. The roof, front and back come off is less then 5 minutes.
Nice not to have the snow flying in my face. In this pic I finished my driveway and the tractor is in the street which had not been cleared yet.
213137 (A64276)
213137 (A64276)
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
2018 CATERPILLAR 573D FELLER BUNCHER (A64276)
2018 CATERPILLAR...
2011 PETERBILT 386 (A67714)
2011 PETERBILT 386...
