Comparison JD 2305 vs JD 2320
/ JD 2305 vs JD 2320 #41
2320 would be nicer smoother ride, because of the larger tires. My 2210 rode so rough in the woods, because of the pee-wee tires. The 2520 is like a Caddy compared to a Geo Metro! :laughing:
/ JD 2305 vs JD 2320 #42
get the 2320. I havent used either of them, but i have used several 2210's and a 4100 gear. The 4100 had so much more "tractor" to it over the 2210's that i prefered it over the 2210's. Sadly, the 4100 was in a barn fire and was destroyed. :( Now replaced by a BX24, There is a huge difference in the capabilities between the 2. Yes the 2305 has a lower stance but that limits you in a lot of ways. You cant lift implements as high (auger, boxblade, tiller, etc), lower clearance means less running on uneven ground with deep ruts. The 2320 sits higher, lifts implements higher, has more 3 point lift capacity, larger tires for better ride, larger frame which makes the 2320 more "heavy duty" than the 2305. Also, you gain foldable ROPS for low clearance garage doors and getting under trees for mowing.
/ JD 2305 vs JD 2320 #43
I've owned a 2305 for three years and can now better understand why the 2320 is a better deal long term. The hydraulics are better, the ROPs is collapsible, you have position control for things like box blade, and other rear implements. The 2305 has a limited cat. 1 hitch, meaning you will have a bit of trouble now and again with getting implements on and off the rear hitch. The 2320 is heavier, and a bit more stable than the 2305. I had no experience with tractors when I purchased the 2305, but I now better appreciate why the 2320 is more expensive, but worth every penny extra.
/ JD 2305 vs JD 2320 #44
I just invested in a "D" mid mount mower for my 2320 so as to have two mowing machines, and that little thing mows great. It is also something my elderly dad can use if I am unable to help him. I will say if anyone is in doubt, go for the 2320 over the 2305. I even would say go for the 2320 over an X series for mowing duties, and I have had several of them as well. It is also a great mowing little tractor. My dream is to have a 1500 series front cut mower, maybe one day. I also have a 950 ZTR that I can haul around when mowing better than the 2320. It is a great mowing ZTR, but I am not enthused that much with the ZTR concept.
John M
/ JD 2305 vs JD 2320 #45
Why would you say mow with a 2000 series over a X series?
/ JD 2305 vs JD 2320 #46
Just back from the dealer about a new mower, the X749 sells for about the same as the 2320. The two are different animals though and I am still looking at the X749 for now. If choosing between the 2305 and the 2320 I think the latter is the hands down winner.
/ JD 2305 vs JD 2320 #47
My X475 is hands down a better mower than my 2210 was, so if you want a mower, the X series is awesome.
/ JD 2305 vs JD 2320 #48
I hope the X749 is the ticket for my mowing and pine needle raking. This should also run my small 3pt chipper for what its worth.
/ JD 2305 vs JD 2320 #49
I believe we would have been better off with a X749 if it was not for the ROPS.
/ JD 2305 vs JD 2320 #50
the 2305 meets my needs best. i wanted a lower stance than the 2320. the x749 seemed too much like a large garden tractor.
/ JD 2305 vs JD 2320 #51
^^^^^^^^ Thats because thats exactly what it is. :confused2:
/ JD 2305 vs JD 2320 #52
I agree, from the appearances you do some brutal work with the 2305.:laughing:
I don't care about the rops on the rider as I have no intentions of getting on slopes that would cause concern. All the other tractors do have protection though.
/ JD 2305 vs JD 2320 #53
I'm sure a clever fabricator could build a ROPS for the 'X' series. I know I'd be looking into doing that if I had one.
/ JD 2305 vs JD 2320 #54
We do use our equipment pretty hard.:eek:
Since that picture, my son has taken down five ice storm damaged trees and has a couple more to do, so we don't have to look up while mowing.
/ JD 2305 vs JD 2320 #55
JDTank,
I have owned and mowed extensively with an X series 485,495,720,and 595. I have had both the 54 and 62c mower decks. I am a big fan of the X series tractors. They are Cadillacs and awesome machines. My online infatuation with them is well known, but I can say that the 2320 is a better mowing machine than the X series on the lawns that I do. It is faster, even in A range, the large tires make for a smoother ride, it SEEMS to have more power, though this likely is an illusion, it lacks a RIO switch and cuts as well or slightly better. I cannot peak to the 2210 or 2305 and how it mows in comparison, but this is a very different machine than a 2320. My point with interjecting this is that a potential buyer who may be interested getting a true compact tractor (I view the 2320 as the initial true compact made by JD) and a sub compact or top end GT but is afraid it may not mow well, may be interested in considering something like a 2320 for only a tiny bit more money. My dealer even was advising people that the X series was a "10 times" better mowing machine than a 2305 or 2320 but is now second-guessing that advice. While X series tractors are great mowing machines and a true pleasure to use, the 2320 as an example is a great mowing machine and worth consideration.
John M
/ JD 2305 vs JD 2320 #56
I have a 2305 and it perfect for me as my main use is mowing and blowing. If I had a larger piece of land I would have went with a 2520. I feel if your getting a larger tractor it should probably have more power. Thats just my opinion. All good machines! If its green can it be wrong?
/ JD 2305 vs JD 2320 #57
My 2520 is pretty darn big for a lawnmower, and its not alot bigger than a 2320. just my opinion. I have R4 tires tho, so maybe turfs would not cut in at all.....?
/ JD 2305 vs JD 2320 #58
Deadman, I do feel as though I am sitting up a bit when using the 2320 v. my ZTR or an X series machine, but these 2020 series tractors are so maneuverable it operates as a smaller machine. For a tiny lawn, I think it would be too much, but I figure most folks looking at such machines do not have tiny lawns. The 2520 if I recall is a fair bit longer than a 2320 which may make it seem a bit on the large side. My tractor has R4 tires, and does not tear up grass at all, though it will compress the grass and dirt when the ground is wet, but really only when almost too wet to mow. I suspect the turf would be better in that case, but I also do a fair amount of loader work and do not wish to limit that.
John M
/ JD 2305 vs JD 2320 #60
Just purchased a 2520 and 62D mmm. I can mow closer and turn sharper with this than my JD317 with 48" deck. Plus 2x faster and smoother, very impressed with this as a mowing machine. My FIL tried it and was also impressed. He thought it would be too big and clumsy, but after trying it he had a big smile on his face and said he couldn't believe how agile it was.
7067CFL (A59228)
7067CFL (A59228)
2018 INTERNATIONAL 4300 NON CDL 26FT BOX TRUCK (A59904)
2018 INTERNATIONAL...
(60) 2"X8"X12' METAL FRAME WALL STUDS (A60432)
(60) 2"X8"X12'...
UNUSED FUTURE RR78-78" HYD ROCK RAKE (A60432)
UNUSED FUTURE...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
RITENHOUSE 400 GALLON ORCHARD BLOWER (A60430)
RITENHOUSE 400...
