JD 2210
/ JD 2210 #1
Tim Baer
York,Pa
JD 2210
When i pull up on the yellow knob the pto clutch seems to slip
/ JD 2210 #3
:welcome:
I don't think the 2210 has a clutch, is hst. I think your belt might be slipping. Remember to engage at a lower RPM then raise the rpm as needed.
/ JD 2210 #4
Welcome to TBN!!!
Can you give a bit better description of what you mean by "slipping"? Is this the rear PTO or the mid PTO?
The 2210's PTO isn't belt driven, but if you have a midmount mower, that drive belt might be slipping.
We're neighbors, BTW...I'm out in the Red Lion/Windsor area.
/ JD 2210 #8
Ooops......I was assuming its was mmm. You know what happens when you assume though. ;)
It probably is a midmount mower, but let's see if the OP responds wih more information. That doesn't always happen though...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
Winco 12-Ton Fertilizer Tender Box (A66408)
Winco 12-Ton...
Skid Steer Deluxe Hitch Plate (A65640)
Skid Steer Deluxe...
1966 Hale Livestock Trailer (A66285)
1966 Hale...
2250' of 5" Tile (A66408)
2250' of 5" Tile...
76in. Skeleton Skid Steer Grapple (A65640)
76in. Skeleton...
