JD 2210
/ JD 2210 #1
Tim Baer
York,Pa
JD 2210
When i pull up on the yellow knob the pto clutch seems to slip
/ JD 2210 #3
:welcome:
I don't think the 2210 has a clutch, is hst. I think your belt might be slipping. Remember to engage at a lower RPM then raise the rpm as needed.
/ JD 2210 #4
Welcome to TBN!!!
Can you give a bit better description of what you mean by "slipping"? Is this the rear PTO or the mid PTO?
The 2210's PTO isn't belt driven, but if you have a midmount mower, that drive belt might be slipping.
We're neighbors, BTW...I'm out in the Red Lion/Windsor area.
/ JD 2210 #8
Ooops......I was assuming its was mmm. You know what happens when you assume though. ;)
It probably is a midmount mower, but let's see if the OP responds wih more information. That doesn't always happen though...
Unused 2022 WIFO WBGS Hydraulic Bale Grabber Skid Steer Attachment (A66734)
Unused 2022 WIFO...
2009 International 4300 Box Truck 24' (A62613)
2009 International...
JLG TELESCOPIC FORKLIFT (A64279)
JLG TELESCOPIC...
PAIR OF PIPE RACKS (A68842)
PAIR OF PIPE RACKS...
LADDERS (A68842)
LADDERS (A68842)
2014 KOMATSU PC170LC-10 EXCAVATOR (A65053)
2014 KOMATSU...
