JD 2210
   / JD 2210 #1
Tim Baer
York,Pa
JD 2210
When i pull up on the yellow knob the pto clutch seems to slip
   / JD 2210 #3
:welcome:
I don't think the 2210 has a clutch, is hst. I think your belt might be slipping. Remember to engage at a lower RPM then raise the rpm as needed.
   / JD 2210 #4
Welcome to TBN!!!
Can you give a bit better description of what you mean by "slipping"? Is this the rear PTO or the mid PTO?
The 2210's PTO isn't belt driven, but if you have a midmount mower, that drive belt might be slipping.
We're neighbors, BTW...I'm out in the Red Lion/Windsor area.
   / JD 2210 #6
Ooops......I was assuming its was mmm. You know what happens when you assume though. ;)
   / JD 2210 #8
It probably is a midmount mower, but let's see if the OP responds wih more information. That doesn't always happen though...
2025 Swict 72in Bucket Skid Steer Attachment (A50322)
2025 Swict 72in...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
RoGator 844 sprayer (A50490)
RoGator 844...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
DRIVELINES (A50854)
DRIVELINES (A50854)
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
