JD 2010 Axel Hub Problem
/ JD 2010 Axel Hub Problem #1
Farwell
Farwell, Michigan
JD 2010
I own a 1965 JD 2010 Row Crop that has had a couple issues with the rear hub and hub cap that holds the wheel to the axle. The first time the wheel actually fell off the tractor because the key that locks the axle shaft to the wheel came out due to loose hub cap bolts that I didn't find when inspecting the tractor.
Today I was moving some dirt with my FEL when I heard a bang. I looked the tractor over quickly and couldn't find any problem but decided to quit working until I found the source of the noise. I found two of the four bolts missing that hold the hub cap, the key and the hub to the axle. The bolts were there when I last inspected the tractor. When I had the first problem I torqued the four bolts according to the service manuals specs. Any idea what could be causing my problem?
2022 John Deere 6R 130 Tractor (A63111)
2022 John Deere 6R...
2015 Ford Transit 250 Cargo Van (A61573)
2015 Ford Transit...
35" EXCAVATOR BUCKET (A64280)
35" EXCAVATOR...
2003 Ford Ranger Pickup Truck (A61573)
2003 Ford Ranger...
2016 MACK CXU613 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2016 MACK CXU613...
2020 John Deere R4044 Sprayer (A63111)
2020 John Deere...
