Jd 1530 hydraulic problem
/ Jd 1530 hydraulic problem #1
jrraff
John deere 1530
My tractor has a strange hydraulic problem at idle speed I have 2200# oil pressure. when I go to increase engine speed the pressure drops to 1600#.
the pressure control valve is activating at this point to maintain power steering.
I have checked all of the spring loaded valves, none had a broken spring. I also inspected the hyd pump, no broken spring , some wear but nothing excessive, nothing was binding and the pistons showed no signs of scoring.
Any one have a thought to my problem?
/ Jd 1530 hydraulic problem #2
From what you said, the steering valve assembly may only require 1600 psi, and dumps the rest. Where are you reading the pressure. Is the gage just after the pump, before any valve? There are valves that can split the flow, say 70/20 % and the relief valve for the steering assembly may be set to 1600 psi. I would think that steering systems would not use real high pressure.
2006 Volvo VNM S/A Day Cab Truck Tractor (A64556)
2006 Volvo VNM S/A...
PALLET OF GANDY APPLICATORS (A64278)
PALLET OF GANDY...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
2022 EZ-GO ELITE...
2017 Autocar Xpeditor T/A Heil V-161 28Yd Front Loader Garbage Truck (A61573)
2017 Autocar...
2018 JOHN DEERE 60G EXCAVATOR (A64279)
2018 JOHN DEERE...
