JD 110 TLB Problem
/ JD 110 TLB Problem #1
Senec
South Jersey
John Deere 110 TLB
I have a 2007 JD 110 TLB and have problems with the hydrostatics. When I operate either the loader or the hoe it dosen't matter, for as short as 20 min. the thing stops and flashes -... if I continue to operate a bunch of codes flash and will not move till I disconect the battery for a couple of hours or wait over night and it clears it self. The code say I'm depressing both F and R pedals but I'm not. Like I said it even happens if I'm diggin a trench. It's been to the shop and they claimed to fix it. but it's getting worse. I just moved some dirt around the yard and 20 min Bang it stops and won't move. I think it's a temp problem because I haven't had the problem in the winter.
Anyone have these problems?
/ JD 110 TLB Problem #2
No problems like yours so far (since 2005 with close to 500 hrs) but it sounds like it may be a computer problem. I would first check the wiring from the pedals and from the rear toggle switch to the transmission and computer for obvious things, loose or dirty connectors, pinched wires. I would also find the computer to make sure it isn't covered with dirt causing it to overheat. From your decription though it is going to be the computer failure most likely.
If you still have warranty I would take it to the dealer.
Steve
/ JD 110 TLB Problem #3
I'd call deere customer service, someone will call you and get you and your dealer on a three way call. Deere's real good about customer service IMHO.
How many hours on your 110? Steve's line of thought sounds right. I sounds to me like a sensor wiring issue.
Matt
PALLET OF FLANGE CUT-OFF VALVES (A67714)
PALLET OF FLANGE...
Renaldo GVB63520-B (A64911)
Renaldo GVB63520-B...
2014 DIAMOND C 45HDT CAR HAULER (A67714)
2014 DIAMOND C...
2022 JCB 509-42 TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42...
2007 Mazda 3 Sedan (A66738)
2007 Mazda 3 Sedan...
213141 (A64276)
213141 (A64276)
