JD 1050 2wd
/ JD 1050 2wd #1
emmitjones
john deere 1050
I am looking for help with a 1986 JD1050 2wd that I recently bought. I am trying to do some repairs to it and and need some ssistance with the front wheels as one of them has rusted through and the other is probably not far behind. I will attempt to get the holes welded up but in the event it is not salvageable, does anyone have another solution as to another type wheel that will fit? I understand that Yanmar made parts are becoming difficult to find for this tractor.
Thanks!
/ JD 1050 2wd #2
You are pretty much stuck. Maybe different hubs that use the same inner race on the bearing. Then you can use stand 6 lug ag wheels.
/ JD 1050 2wd #3
You might find that another JD model rims will fit. I bought tires and rims for my '94 JD 970 that were part #'s for a JD 990.
I wouldn't be surprised if the rims for say, a 2WD JD 4005 would bolt right up!
Check with your local JD guys.
AKfish
/ JD 1050 2wd
I was able to get the wheel repaired at a local welding shop for $35! Hopefully this will last for a while!
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
New 2x27 Ratchet Strap (A65583)
New 2x27 Ratchet...
(15) IH Suitcase Weights (A66408)
(15) IH Suitcase...
40ft Shipping Container (A65579)
40ft Shipping...
2022 CATERPILLAR 289D3 SKID STEER (A64279)
2022 CATERPILLAR...
2014 Ford F-150 Pickup Truck (A64556)
2014 Ford F-150...
