Jaws for pulling small trees
/ Jaws for pulling small trees #51
I dunno, I'm kind of leaning twoard the hedgerow busters used on the Shermans Danno1 was reminded about. Think this could be a no problem deal till you got it home to say honey, look what I bought today.
/ Jaws for pulling small trees #52
Chilly,
That looks awesome! Thanks for the pic of your A-Frame and your pipe/chain. I like the feet.
Do you have any better pics of how the chain lays in the top of the a-frame?
/ Jaws for pulling small trees #53
Chilly,
Actually I don't.. but I will snap a couple when I use it again. I used a piece of 1/2 inch steel plate about 6 inches long and three or four inches wide welded to one leg, and bolted through to the other to allow the frame to fold. The top edge has a slot cut in it 1/2 inch wide and 3/4 inch deep to hold the chain from slipping. When the frame goes over forward, the tractor automatically pulls the chain out of the slot and carries on.
If I had to do it again, I'd use better grade steel for the top plate, mine's been bent a bit. Maybe armor plate or tool steel would be better, I used mild steel.
The only real problem with it is the weight, it's about 40 pounds I'd guess. We only use it for stubborn stumps or in spots where you don't want to go with the tractor. As usual, traction is the limiting factor when pulling stumps. Even with R1's, the 3400 will dig three nice deep holes if the stump doesn't come loose easily.
Sean
/ Jaws for pulling small trees #54
I had thought about just sliding a short piece of pipe over the chain. Wrap chain around tree. Hook the hook on the tractor end of the pipe. No welding.
2025 AGT STSD10 72" Grain Drill (A60463)
2025 AGT STSD10...
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 Chevrolet...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2023 Deere 317G (A60462)
2023 Deere 317G...
2020 DRAGON ESP 150BBL ALUMINUM (A60736)
2020 DRAGON ESP...
