Jacking up a trailer
/ Jacking up a trailer #1
MillWeld
Durham NC
Ford 641
I looked at videos about adjusting trailer brakes and one of them (How to Adjust Trailer Brakes - 5 Easy Steps) said in writing on the screen at 1:55 minutes to never jack on the axle - use the frame. Why? I have always jacked on the axle very close to the drum. I have seen other videos that jacked on the axle, too. What gives?
/ Jacking up a trailer #2
Remember, not everything on the internet is correct. I always use the axle...
Wonder what others will say....
To confirm that I lift on the axel right where the saddle clamps / U bolts are... Not on the pipe itself.
/ Jacking up a trailer #3
Well, when you have a loaded goose neck on three 7K axles and you jack one up you're putting up to a 21K load on one axle/set of springs. Check how much compression is already on the system then decide if you want to add compression do to your task, unloaded single axle trailer no problem, loaded dual axle trailer probably not a good idea.
I have two 7K axles and I jack them up at the same time and side to adjust brakes when the trailer is empty. (I put a bar under the axles right at the brake drum and put a jack at the midpoint of the bar and lift. This gives easy access to make adjustments.)
/ Jacking up a trailer #5
Anyone that believe's everything on the web and specifically u-tube is fact should take a break. Anyone that thinks the jack is supporting the intire load when one wheel is lifted shouldn't attempt checking air in tires much less change tires or adjust breaks. Doesn't matter anyhow because I don't use a jack if trailer is loaded. I pull tire next to one I'd like raised onto a leveling block. Before pulling onto block I place a spacer between equalizer and frame to limit spring travel.
/ Jacking up a trailer #6
Torsion axles do not spread the load like some leaf spring setups do. Heck, many leaf spring ones do very little to spread the load. So jacking up a axle can easily put more of a load on one axle end than intended.
On the other hand I would be surprised if a person was trying to adjust their brakes on a heavily loaded trailer.
/ Jacking up a trailer #9
I lift on the axel right where the saddle clamps are. The biggest reason I do it that way is it only has to be lifted an inch or so to gorge tire off the ground. If you’re lifting on the frame you have to lift several inches.
2008 FORD F150 REGULAR CAB PICKUP TRUCK (A66091)
2008 FORD F150...
2011 PETERBILT 386 (A67714)
2011 PETERBILT 386...
SULLAIR 1109E/A 3-PHASE COMPRESSOR (A67714)
SULLAIR 1109E/A...
2009 TRAIL KING PNEUMATIC TRAILER (A67714)
2009 TRAIL KING...
DEUTZ FAHR 4080E TRACTOR (A65057)
DEUTZ FAHR 4080E...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
