Jacking up a Tractor Question
   / Jacking up a Tractor Question #1
Muskoka Bill
Bracebridge Ontario
Kioti CX2510
Hello I am new to tractors, I just purchased a Kioti CX2510 and I am thinking of grooving the R4 tires for better winter traction. (I can't use chains or studs on the paved driveway). I would like to be able to jack up each tire separately when I come to groove that tire. Where do I put my 2 1/2 ton jack? There is no mention of jacking in the manual. Can I put the jack and jack stands under the front or rear axle casing or will I damage the casing? Your input is welcome. Thanks Bill
   / Jacking up a Tractor Question #2
I would just grove the top of the tires and move it forward a few times.
   / Jacking up a Tractor Question #3
Is grooving a R4 tire really going to do anything?
Try adding more weight
There are lots of discussion on TB about grooving and the consensus I arrived at is that it will help with improved traction on snow but not much better on ice. I purchased a MK Martin Meteor 60" pull type snowblower (500 lbs) and I have a hill in the driveway so I may need the improved traction in the rear and front tires. I have the tire grooving iron and blades so it is just my time. But getting back to the original question ?
   / Jacking up a Tractor Question #5
On my M9's I lift both front wheels with a 10 ton hydraulic jack centered under the front axle pivot casting and the back under the drawbar housing. Lift blocks added of course.
No clue about 'grooving tires' I run R1 radial ag tires.
   / Jacking up a Tractor Question #6
I jack up my tractor when I install the chains before winter. I can life the entire back end of the tractor by lifting on the drawbar. Then put jack stands under each axle.
This video shows how I do it.
at about the 3 minute mark.
   / Jacking up a Tractor Question #7
I have used a 3 ton floor jack dead center for both the front and rear, then lowered onto jack stands. I would recommend just rolling the tractor as you groove though.... you will want to take a break every quarter tire or so anyway.
Grooving R4 tires makes a significant difference in snow traction.
   / Jacking up a Tractor Question #8
I have tried jacking up just one side of my tractor and found it impossible to do using anything on the tractor solid enough to place the jack. It's narrow enough that both sides go up, just a little unevenly.
If you do have one side off the ground and the other on the ground you won't be able to turn the wheel anyway, both wheels need to be off the ground to turn them manually, unless yours works differently than mine. I also would not want to have my tractor up in the are for an extended period of time, sounds like an accident waiting to happen.
I would either take the wheel off and have that side on a jack stand so that I knew it was stable or do what other suggest and move the tractor.
You have made a good point that I never thought about in that both wheels probably have to be off the ground to be able to turn a wheel manually. I will just move the tractor rather then try jacking it up when I start the tire grooving job.
Thanks to all who shared their knowledge with a beginner !!
   / Jacking up a Tractor Question #10
Not so unless you do not have a differential, which many tractors do....
Just jack it up, put a pair of jack stands under it and be happy....
4 Cubic Yard Dumpster (A55851)
4 Cubic Yard...
2017 MONSTER MOTO MM-B80 (A57192)
2017 MONSTER MOTO...
Deere 310L (A53317)
Deere 310L (A53317)
6ft S/A Trailer (A55853)
6ft S/A Trailer...
(2) UNUSED 18.4-30 TRACTOR TIRES (A57192)
(2) UNUSED 18.4-30...
(3) 16" X 30# UP TO 9.5' I-BEAM (A57192)
(3) 16" X 30# UP...
