Iseki TX1500 valve seat inserts
/ Iseki TX1500 valve seat inserts #1
Macz
Mount Gambier
iseki TX1500
Does anyone know the valve recession for a Mitsubishi TX75 engine?
i.e. far far above or below the head surface the valve heads should be when assembled?
Typo alert,
The engine is a Mitsubishi KE75
/ Iseki TX1500 valve seat inserts #3
Sometimes you can work it backwards, if you know how high above the valve spring seat the end of the valve should be. But certainly not far, far above the head surface! If you see that, you may see a gap under the seat where it has moved.
