Yes, that is absurd and you should ignore it.
These Kawasakis do have some weaknesses, which are infamous. The company struggled to make cam gears that would last. Plastic is not the best material for cam gears, but Honda and Kohler use them in some engines and their records seem to be better.
That said, the cam gears are so bad in Kawa twins that there have been cheap aftermarket kits available for years. Problem is, you have to pull the engine and take it completely apart.
I got a 4x6 Gator here a couple of years ago, where someone attempted the cam gear update, and did it incorrectly. He lost the oil pump spring, for one.
All of these OHVs need periodic attention to their valve clearances, but it is usually very easy. Hard to start is the clue.
Also, it you have a diaphragm fuel pump, E10 fuel makes the rubber stiff, and they often need replacement every few years.
