300 hours - clean combustion chamber, clean and lap valve seat surface
   / 300 hours - clean combustion chamber, clean and lap valve seat surface #11
Yes, that is absurd and you should ignore it.
These Kawasakis do have some weaknesses, which are infamous. The company struggled to make cam gears that would last. Plastic is not the best material for cam gears, but Honda and Kohler use them in some engines and their records seem to be better.
That said, the cam gears are so bad in Kawa twins that there have been cheap aftermarket kits available for years. Problem is, you have to pull the engine and take it completely apart.
I got a 4x6 Gator here a couple of years ago, where someone attempted the cam gear update, and did it incorrectly. He lost the oil pump spring, for one.
All of these OHVs need periodic attention to their valve clearances, but it is usually very easy. Hard to start is the clue.
Also, it you have a diaphragm fuel pump, E10 fuel makes the rubber stiff, and they often need replacement every few years.
People bring up the plastic cam gear in Kaw, but the truth is the average failure was in the 800-1200 hr range.
   / 300 hours - clean combustion chamber, clean and lap valve seat surface #12
While we're talking about onerous manual requirements, the Kawi F730V manual also says to let it warm up 3 to 5 minutes before placing the engine under load. Seem excessive?
   / 300 hours - clean combustion chamber, clean and lap valve seat surface #13
The Ventrac I own has a Kawasaki V in it and it definitely needed valve adjustment at 300 hours.
I did a compression test on it to confirm it did not need a valve lap.
   / 300 hours - clean combustion chamber, clean and lap valve seat surface #14
You have probably dealt with more of these than I have, but 800+ hours does not seem like a lot for an engine used in a vehicle. I have also seen broken Honda plastic cam gears, and also their plastic cam. There are many many consumer-grade lawn tractors with well North of 1000 hours.
For comparison, the 3-cyl 660cc Mits engine in the Toro I am working on is just shy of 5000 hours.
I'm at 1200 hours on mine now. What am I in for, and more importantly, what should I be doing about it?
A commercial mower engine failing at 1200 hours is pathetic. Many commercial guys do more than that in a single season. I would really expect this engine to go at least 2000 - 3000 hours, which at my usage and deck deterioration rate, will be the lifetime of the mower.
I can do that. I suspect I can find the compression spec's in my service manual, and I assume the compression testers I have from working on cars many years ago will work okay here.
   / 300 hours - clean combustion chamber, clean and lap valve seat surface #16
If it helps, I have the model FD851D Kawasaki engine and yes I used the standard compression tester.
Before I did anything my compression was at 70psi. After I completed the valve adjustment my compression was at 120psi at 310 hours.
Cool. I do all my yearly OPE maintenance late December or early January, so I'll post back here with my results. It'll be interesting to see what a 17 year old 1200 hour Kawi V-twin throws up on the compression test.
I don't know how the original owner treated it, I inherited the thing with the house around 300 hours, but it's had yearly oil and filter changes ever since. I average 70 hours of mowing + up to 30 hours of towing a walnut harvester or leaf blower, on that machine each year.
   / 300 hours - clean combustion chamber, clean and lap valve seat surface #18
If you are talking about the Kaw in the 757 that mower and engine should be new enough to have the metal cam gear. The plastic cam gear issue mainly effected the models from around 98-99 model years when they changed from plastic to metal in those engines. So the FD590V in the 325-345 series mowers and the FD620D in the 445.
If you are talking about the Kaw in the 757 that mower and engine should be new enough to have the metal cam gear. The plastic cam gear issue mainly effected the models from around 89-90 model years when they changed from plastic to metal in those engines. So the FD590V in the 325-345 series mowers and the FD620D in the 445.
Good to know. Just looked this up, based on your post, and it seems they stopped using plastic cam gears in or around 1998. I think my mower was purchased new in 2007, so seemingly no chance for an overlap.
Thanks!
   / 300 hours - clean combustion chamber, clean and lap valve seat surface #20
Absolutely ridiculous to do anything other than check clearances & regular service if it’s running ok.
90cummins
2020 Case TR310B Skidloader (RIDE AND DRIVE) (A50774)
2020 Case TR310B...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
T3 Motion Patroller Segway (A51694)
T3 Motion...
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
Case IH 2608 8 Row Corn Head (A52349)
Case IH 2608 8 Row...
2011 Mack CHU613 T/A Day Cab Truck Tractor (A51692)
2011 Mack CHU613...
