Is white pvc mipt used for dwv fittings fine, coarse or 2.44 fine?
   / Is white pvc mipt used for dwv fittings fine, coarse or 2.44 fine? #1
homedad
central/ se michigan
Kubota L3130DT
I purchased a food grade IBC tote for water at my property and need a fitting to screw onto the valve. Amazon wants to know the thread type. The IBC is 3 hours away but when last there I unscrewed the cap and went to TSC to try and create a fitting. The cap screws fine onto a male threaded 2" white PVC adapter used for drain, waste and vents. Does anyone know if its fine, coarse or 2.44 fine?
   / Is white pvc mipt used for dwv fittings fine, coarse or 2.44 fine? #2
There's a few. The two most common are S60x6 (coarse, metric but close to 2" without the camlock), and 2" camlock, fine thread.
I saw a great uTube video about a guy that used a 2" rubber connector to attach the PVC bung and garden hose valve. I've used that.
Thanks.
I ended up purchasing all 3 and lo and behold…non of them fit. I went to HD and in 30 minutes made one that works fine out of White PVC DWV and a short galvanized nipple. I regularly think Amazon just makes errors easier.
2017 SANY SY365C LC EXCAVATOR (A51246)
2017 SANY SY365C...
New/Unused 30ft x 65ft x 15ft Storage Shelter (A51573)
New/Unused 30ft x...
New Holland Boomer 55 Tractor (A52384)
New Holland Boomer...
2010 POLARIS RANGER 4X4 4 SEATER UTV (A52576)
2010 POLARIS...
FAE 150/540 LOT NUMBER 137 (A53084)
FAE 150/540 LOT...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2017 Ford F-150...
