Is white pvc mipt used for dwv fittings fine, coarse or 2.44 fine?
   / Is white pvc mipt used for dwv fittings fine, coarse or 2.44 fine? #1
homedad
central/ se michigan
Kubota L3130DT
I purchased a food grade IBC tote for water at my property and need a fitting to screw onto the valve. Amazon wants to know the thread type. The IBC is 3 hours away but when last there I unscrewed the cap and went to TSC to try and create a fitting. The cap screws fine onto a male threaded 2" white PVC adapter used for drain, waste and vents. Does anyone know if its fine, coarse or 2.44 fine?
   / Is white pvc mipt used for dwv fittings fine, coarse or 2.44 fine? #2
There's a few. The two most common are S60x6 (coarse, metric but close to 2" without the camlock), and 2" camlock, fine thread.
I saw a great uTube video about a guy that used a 2" rubber connector to attach the PVC bung and garden hose valve. I've used that.
Thanks.
I ended up purchasing all 3 and lo and behold…non of them fit. I went to HD and in 30 minutes made one that works fine out of White PVC DWV and a short galvanized nipple. I regularly think Amazon just makes errors easier.
2014 John Deere 630FD Draper Head (A53342)
2014 John Deere...
2015 VOLVO VNL TANDEM AXLE DAY CAB (A52576)
2015 VOLVO VNL...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR1BJ325796 (A51572)
2011 International...
2 Disc Heavy Duty Bottom Plow (A51573)
2 Disc Heavy Duty...
20711 (A50323)
20711 (A50323)
1973 FORD 9000 TANDEM AXLE DUMP TRUCK (A52576)
1973 FORD 9000...
