Is white pvc mipt used for dwv fittings fine, coarse or 2.44 fine?
   / Is white pvc mipt used for dwv fittings fine, coarse or 2.44 fine? #1
homedad
central/ se michigan
Kubota L3130DT
I purchased a food grade IBC tote for water at my property and need a fitting to screw onto the valve. Amazon wants to know the thread type. The IBC is 3 hours away but when last there I unscrewed the cap and went to TSC to try and create a fitting. The cap screws fine onto a male threaded 2" white PVC adapter used for drain, waste and vents. Does anyone know if its fine, coarse or 2.44 fine?
   / Is white pvc mipt used for dwv fittings fine, coarse or 2.44 fine? #2
There's a few. The two most common are S60x6 (coarse, metric but close to 2" without the camlock), and 2" camlock, fine thread.
I saw a great uTube video about a guy that used a 2" rubber connector to attach the PVC bung and garden hose valve. I've used that.
Thanks.
I ended up purchasing all 3 and lo and behold…non of them fit. I went to HD and in 30 minutes made one that works fine out of White PVC DWV and a short galvanized nipple. I regularly think Amazon just makes errors easier.
2018 CATERPILLAR TH514D TELESCOPIC FORKLIFT (A50458)
2018 CATERPILLAR...
2023 KENWORTH T680 TANDEM AXLE SLEEPER (A50046)
2023 KENWORTH T680...
2020 John Deere 60G- Hydraulic thumb- Case Drain- Angle Blade (A50397)
2020 John Deere...
2020 KUBOTA SVL95-2S SKID STEER (A50458)
2020 KUBOTA...
2009 Ford Ranger Pickup Truck (A48081)
2009 Ford Ranger...
2010 Icon LT-A617.4+2G Electric Golf Cart (A48082)
2010 Icon...
