Is there an implement that will ?????
/ Is there an implement that will ????? #1
gotrocks
Platinum Member
Phenix City Alabama
B-2910 delivered 8/23/01
Hello TBN friends,
You have helped me in the past. Now I would like to ask for suggestion as to what to look/ask for in an attachment that I can put behind my 2910.
I have a tiller and can prepare the soil but then I want to dig furrows at least 6 inches deep and 6 to 8 inches apart and cover the full width of the tire tracks in one pass.
Is there such a plow?
Thank you for all suggestions.
Happy Father's Day to all you Pops and Grandpops. /forums/images/graemlins/smile.gif
/ Is there an implement that will ????? #2
<font color="blue">...dig furrows at least 6 inches deep and 6 to 8 inches apart and cover the full width of the tire tracks ...</font>
Hi,
I believe there is... /forums/images/graemlins/smile.gif
I may have a picture home..., so check a bit later... /forums/images/graemlins/wink.gif
/ Is there an implement that will ????? #3
How about removing every odd/even/other row of tines on your tiller?
/ Is there an implement that will ????? #4
Look around for an old single row cultivator. They generally have 6 leaf springs with small point shovels. Find some barley corn shovels, and put two on the leaf springs closest to the width you want the rows. Remove the rest. Mine even has multiple holes for the leaf springs.
/ Is there an implement that will ????? #5
They use simple middle busters (adjustable) and basically gang them together as many or as few as you want... (say that quick 5 times /forums/images/graemlins/blush.gif)
/ Is there an implement that will ????? #6
Good morning, John. In my part of the country a lot of folks call that a "bedder" and they "bed" their gardens in the winter while not in use.
/ Is there an implement that will ????? #7
Morning John and Bird. Bird, when you say "bed their gardens in the winter" does that mean turning under remaining vegetation? If not what is the advantage digging furrows? Can you tell I haven't done much gardening but it is on my mind. /forums/images/graemlins/ooo.gif
MarkV
/ Is there an implement that will ????? #9
</font><font color="blue" class="small">( If not what is the advantage digging furrows? )</font>
Mark, I never did that to my garden and I asked some of those who did, why? Answers I got ranged from "I don't know; that's the way my dad did it" to "provides more surface area, holds the moisture in better and lets the moisture get down deeper."
/ Is there an implement that will ????? #10
Hi Ken,
I would have posted a cultivator, but he wanted "furrows" as wide as his rear tires... (I never asked why.../forums/images/graemlins/wink.gif)
Perhaps, I misunderstood... /forums/images/graemlins/confused.gif
/forums/images/graemlins/laugh.gif
/ Is there an implement that will ????? #11
<font color="blue">...call that a "bedder"... </font>
Hi Bird,
You gots to remember I'm from New York... /forums/images/graemlins/shocked.gif /forums/images/graemlins/laugh.gif
/ Is there an implement that will ????? #12
Now, Now John. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
MarkV
/ Is there an implement that will ????? #14
<font color="blue">...available with up to 15 inch sweep points ...</font>
Very nice Ken... /forums/images/graemlins/smile.gif
(What is the approximate replacement cost of the 15" shovels?)
Thank you all who have responded.
I guess I was not very clear regarding the results I'm looking for.
I would like to have one pass leave multiple furrows (trenches). In other words if the implement was 4 feet wide and spacing was 6 inches, I would have 9 furrors after each pass, or 7 if spacing was 8 inches.
Ken, what is the name of the implement you have pictured?
Thanks again to everyone that has answered and those yet to answer.
After the rain we just had, "it is too wet to plough".
/ Is there an implement that will ????? #16
The plow Ken showed is what my neighbor called a "chisel plow". He had a bigger, heavier one that was a pull behind (raise and lower hydraulically) instead of a 3-point; 2 inch wide chisel points spaced 12" apart and he used it in the pastures (including mine). It supposedly served the same purpose as aerators on your lawn, allowing air and moisture down into the ground.
/ Is there an implement that will ????? #17
Hi--The Mfgr calls it a "Field Cultivator" locals call them rippers or shank tillers--they dont go as deep as a chisel plow--These machines have variable spacing in width and 4 bolts removed will drop off a complete shank assembly--Used are usually available under $375 and new 9 shank models $675--Ken Sweet
Sweet Farm Equipment Co. * Disc Mowers Specialists*
/ Is there an implement that will ????? #18
Hi John--Most larger bedder/middle buster/ points available at most ag store outlets for under $25 and under $10 used at salvage yards--Ken Sweet
/ Is there an implement that will ????? #19
The field cultivator that Ken showed is what almost everyone uses in this area instead of a disc harrow. It does a much better job in heavy rocks than a disc. I orders a wide bedder point from my dealer not long ago and it was about $12.
/ Is there an implement that will ????? #20
Hello Jerry--This tool is also what most area tobacco growers use to work the soil, just before transplanting. Works the soil a lot deeper that a disc harrow and with less compaction, which is a killer for tobacco seedlings.--Ken Sweet
Sweet Farm Equipment Co. *Since 1977*
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63689)
2006 Cadillac GM...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
2004 160 LC John Deere Excavator (A62613)
2004 160 LC John...
2023 John Deere 333G for Parts (A61306)
2023 John Deere...
2022 CAT 289D3 (A60462)
2022 CAT 289D3...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
