Buying Advice Is the Front End Loader worth it?
   / Is the Front End Loader worth it? #41
I have two chainsaws. I got them both stuck once. I had to go borrow my Grandpas saw. I could have changed the bar, but it was faster to grab another saw.
I hate it when I pin two saws! The second time I did it I was being extra careful but the trees and the wind had other thoughts. Heck, I hate it when I pin one saw! Especially if it's my JD with the outboard clutch.
But back to tractors, that's one reason why I've got two, so if one dies I can try and rescue it with the other, once I finally get fully moved to Mississippi.
   / Is the Front End Loader worth it? #42
I hate it when I pin two saws! The second time I did it I was being extra careful but the trees and the wind had other thoughts. Heck, I hate it when I pin one saw! Especially if it's my JD with the outboard clutch. But back to tractors, that's one reason why I've got two, so if one dies I can try and rescue it with the other, once I finally get fully moved to Mississippi.
With the assistance from the tractor I have always been able to unpin a saw , but that day I had it somewhere else. When I get the tractor stuck I can borrow my Grandpas rollback with a 15K winch. If I am just mowing a muddy area I try to use the B7100 which I can easily pull out with the bigger tractor.
   / Is the Front End Loader worth it? #43
620 hours on a 2305 here. When I bought my 6 acres I went out to look for a riding mower and ended up with the brand new 2305 and 200cx. While I enjoy mowing with it I'd say 2/3s of my hours have been loader use. And yes you can't beat them for cutting/hauling wood!
   / Is the Front End Loader worth it? #44
I am getting ready to purchase a sub-compact for mowing and tilling on my 5 acre plot and I am torn on the FEL. I have a couple of uses for it right off the bat (move some gravel, haul wood and dirt) but none of them are complete necessities and I have no long term plans for material handling. So, I am torn on the purchase.
The dealers all want you to have one as there is not an SC tractor on any lot without the FEL already installed.
I know it is one of those things I will never regret having, but is the extra $3k worth the investment? I am interested in your stories of why/why not the FEL is worth having or uses you never thought of when you got one.
For the record the front runners now are the Kubota BX2670 and the JD 1025R.
Chris
Cdondanville, let me be the 1st to suggest differently than the others.
1st. You claim no dealer has a scut on their lot without a fel. I've seen 3 dealers I was at that had one or more for sale on their lot.
2nd you mention the bx2670 and jd 1025r as leading candidates. So . . the yanmar 221 and Massey GC1705/1715 didn't interest you . . . or you didn't look enough to go to those dealers to see them ?
3rd. Everyone up till my post is trying to talk you into what has worked for them . . But I'll suggest you should do what works for you. How about buying a used scut with no fel ? Everyone is telling you they won't be worth much . . so you could get one cheap . . reducing your risk of being wrong by a great amount?
You're an adult . . not a little kid . . so if you've really done your homework and put some effort into it . . You've got reasons for thinking as you do . . . you just haven't clearly defined them to us.
So take a used "fel-less" scut off someone's hands . . . Buy it really cheap . . Use it for a year . . and then see. You can always sell it cheap to someone else and at least break even on it or better.
My point . . if you haven't done your homework . . then you need to. If you have really studied and searched and evaluated your needs . . Seen at least 4 or 5 brands of equipment and walked your 5 acres a few times thinking of your uses for a machine . . then greatly reduce your risk of being wrong and go for it by buying used "fel-less" scut (and no not a lawn mower).
   / Is the Front End Loader worth it? #45
Welcome to TBN, Chris. Mine is another voice strongly suggesting you get the loader for your new tractor. Unless you hire all your property maintenance out, you absolutely will find many uses for a FEL, many of which you haven't even imagined yet. It will lift and carry everything from rocks to flower pots, push snow, tear down brush, and even dig and haul dirt.
And mowers
And snowmobiles
   / Is the Front End Loader worth it? #46
Loader is handy and it saves your back. Cannot tell you how many things you will use it for, but I bet i use mine 3-4 times a week. Add forks,a chain, a boom, a tree spade and the options are endless.
   / Is the Front End Loader worth it? #47
The OP is looking at a small tractor, on Kubota .com SSQA is not listed, just Kubota's QA which eliminates the benefit of being able to use a wide range of skid steer implements.
And in order to pass along the cost you've got to sell your great little tractor. I think everyone should have two tractors and 3 chain saws. When I "upgraded" from my B7610 to my M4700 it allowed me to use a tractor at two places, one in Virginia, one in Mississippi :) without trailering.
The quick attach is great but my previous B7510 with FEL did not have one available but four implement hitch pins with clevises replacing the original pins and bolts made changing from bucket to forks pretty quick and easy:D
   / Is the Front End Loader worth it? #48
Chris;
You don't know it yet but, at some point in the future, you will catch the "Grapple Fever" like many others on TBN.
You might consider, as others have noted, getting a little more tractor than you think you need now with a FEL with SSQA attachment. A bit more money now but if you amortize the added cost over several years the cost becomes insignificant.
Good luck with whatever you decide! Check back and let us know which way you go.
Sent from my iPad using TractorByNet
   / Is the Front End Loader worth it? #49
Skip the end loader. Tractors waste fuel, wear out and depreciate. Once you buy a wheel barrow and a shovel, they are maintance free or cheap to fix. Getting older? That's why you have kids, they can do all the work.
Seriously, get the end loader.
   / Is the Front End Loader worth it? #50
Got a real chuckle out of that Dodge Man!
Ford 8510 (A53317)
Ford 8510 (A53317)
WATER TRAILER (A58214)
Atlas Sound Ceiling Speakers (A56860)
Atlas Sound...
2014 Timpte Hopper Bottom (A56438)
2014 Timpte Hopper...
Adams 16T Tender Body (A56436)
Adams 16T Tender...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
