Is the B3030 enough tractor for me?
   / Is the B3030 enough tractor for me? #11
I think you will find the B3030 is more than enough tractor to fill your needs. This is my 5th tractor & i work in the business, i operate a cat 416 backhoe and or a cat 277 r.t. loader at least once a week & i operated large tractors at the 4 year agricultural school i attended. The b3030 is a joy to operate, its well balanced,powerful,comfortable,very quiet & good on fuel. Kubota engineers did a good job on this machine.
I'd appreciate it if someone could tell me a little more about the HD alternator option available for the B3030. Why is it better than the original equipment? Thanks.
   / Is the B3030 enough tractor for me? #13
I am asking the VERY same question,,,is the B3030 enough,,,or just right...i will be using tractor in dense NH woods, digging around a pond, hauling out wood, etc...
so size is a consideration (favoring the B3030) but so are weight and increased stability (favoring the L3400 and the L3130). I also need a backhoe, so that is a factor in my deliberations, and I could conceivably use it for moving snow at some point..... right now I am considering the B3030, the L3400 and the L3130...
If I get the L3130, I might go with the basic (FST) transmission, as I am used to a clutch (on my 1952 JD AR).
What impresses me a lot about the B3030 is the ground clearance, which is listed as 14.6", actually more than the L3400 or the L3130...
Fred (New Hamphire)
   / Is the B3030 enough tractor for me? #14
Standard alternator on B3030 is 15 amps. If you add any more than a 50 watt light for night work there will not be enough output to keep battery charged. I have 4, 50 watt lights mounted on my ROP's. I do not use them with headlights on. Usually only have one set on at a time. I have not had a problem. But if I had known that a larger alternator was available when I bought my tractor. I would have had one put on.
   / Is the B3030 enough tractor for me? #15
</font><font color="blue" class="small">( I'd appreciate it if someone could tell me a little more about the HD alternator option available for the B3030. Why is it better than the original equipment? Thanks. )</font>
As RonH posted..the standard 15 amp dynamo is nothing but a JOKE! Dont plan on decking out the tractor to look like a 4th of July parade..cause it cant handle it! I have one circuit open..factory fused at 20 amp...but then I ony intend on mounting one (1) single 55 watt flood lamp to help get thru the woods if I get caught in the evenings...I have no desire nor intendion of working "at nights" with mine.
I intend on ROPS mounting IT and twin yellow ROPS mounted flashers..and the flashers will be LED models ( point Zip eletrical draw) wired to the 4 ways flasher setup ( factory setup).
Other than those simple mods..Im up the creek electrically. I doubt I'll ever get the alternator kit...but if I were buying new..NOW..I would.
   / Is the B3030 enough tractor for me? #16
FWIW, I have a B7100DT. That's 16 hp at the engine, 48" wb., 48" width, and about 1250 lb with loader. Gear drive, Ag tires, loaded. I live on a pretty well sloped piece of woods with a curved gravel driveway about 800 feet long plus another 5 or 600 feet running up to and through the barn and barnyard. In addition to the loader which never comes off, I have a 6' rear blade and a 4' bush hog style mower marketed by TSC under their Huskee brand.
I have used this little tractor, with two people sitting in the bucket to keep the front end down, to haul a 16' tandem trailer loaded with green lumber up the driveway when my pickup would only sit and spin. The loaded trailer was probably in the 3000 lb range since empty it weighs just about 1000. The trailer load in question was enough to twist the factory bumper hitch on my truck about 15 degrees out of square. The driveway in question was, at that time, built like a ski jump in reverse. People who didn't hit the hill just in front of the garage with a fair amount of momentum, even in summer, would fairly often not make it on the first try. A box truck delivering a new freezer could not make the hill, but sat and spun on the gravel.
I also use it to clear snow, sometimes resorting to the loader when the stuff is so heavy it pushes the tractor around. Sometimes I use an old Cadet to move the snow, too. We get snow up to about 20 inches here during the worst storm of any given winter.
I have used the bush hog with some success, but it's slow. I use second gear out of 6, the second of 3 pto speeds, and lift or lower the 3 point as needed to keep the blade speed up. Mostly I mow multiflora clumps and woodsy undergrowth with it. I usually have to mash the multiflora down with the loader before driving the hog over it. The tractor thinks its on vacation if I just mow grassy stuff.
I have had it in multiflora/blackberry tangles thick and large enough to hold the entire rig about 3 or 4 feet off the ground, but that particular little chore stripped the splines on the lift arm, allowing the tractor to tilt about 30 degrees while the hog was about 30 degrees the other way. I managed to disconnect the hog, -- not fun when in the middle of a 10 or 12 foot high briar patch -- drive the tractor over the multiflora and out of the tangle, then drag the hog out with a chain and the loader. It was a LONG 3/4 mile drive back to the trailer that time.
I think the B3030 will suit your needs just fine. It has plenty of power, and if you need weights, I'd suggest wheel weights over loaded tires for reasons I detailed in another thread. I know they cost more, but you will get a better ride and be far more when driving over obstacles. I would also suggest R4 tires. The turning radius and generally smaller size will make the tractor handier to use than the physically larger L. Make sure the seat works for you. I find the newer Kubota seats have a forward tilt to them that would be unnerving on a downhill. Of course, aftermarket seats can be had for anywhere from 50 to $500 or more, depending on what you want, so don't let the seat dissuade from a particular machine.
   / Is the B3030 enough tractor for me? #17
I own a B3030 and I really like it. (I actually love it but it sounds weird for a grown man to say he loves a tractor. /forums/images/graemlins/blush.gif) It is a joy to drive. It has the best and easiest steering of anything I have ever driven. The tight turning radius was a big factor in my decision to buy. It is amazing that even when turning as tight as possible on grass it will not scuff if you go slow. It is quiet and smooth and has more power than I have ever needed. As far as the seat, I think it is very comfortable and never even thought about it being tilted forward until I read about it here. It is not like a bucket seat in a car that wraps around you and holds you in. I guess it is a personal thing that some dislike but I actually think it is angled perfectly for operating the HST. You do set quite upright on the seat. This allows you to turn around easily to see behind you. I did remove the armrests, though. They just got in my way and my elbows would bump into them when turning the steering wheel. If you are on hills and feel like you are sliding out of the seat then the seat belt will fix that. You should wear it at all times anyway. I am guilty of not wearing it all the time myself but I do wear it when operating the FEL or mowing on rough ground. If I needed a heavier tractor I would not hesitate to buy a Grand L but for my needs the B3030 is perfect. Unless you plan on doing more in the future than you have mentioned I think the B3030 will be a good choice for you.
Thanks again for the input.
I lean toward the B3030. Sizewise, I think my main remaining question is whether it's big and strong and heavy enough to handle my Bush Hog SQ600 (522 pounds) rotary cutter.
My once-a-year mowing is relatively light stuff, mosty grass, hardly any brush.
I probably would leave the FEL on while mowing, for several reasons. But if I mowed without the FEL, would I be apt to lift the front wheels when raising the rear mower?
One further question: Can I successfully "offset" the rotary cutter to one side a few inches (using the telescopic stabilizers) so that the cutting swath is well outside the rear wheels? (I like to keep those nasty hawthorn thorns well away from my tires.)
   / Is the B3030 enough tractor for me? #19
My <font color="green"> JD </font> 60" Rotary Cutter weighs 510 lbs. I have no problems with it when FEL is on tractor. I do not think the addition of 12 lbs will make a difference. At times I have removed just the bucket (FEL has a Quick Coupler) for a better view out front when cutting. It did not make front end bounce off ground when rotary cutter was raised.
   / Is the B3030 enough tractor for me? #20
Do any of you B3030 owners have an aftermarket QA and pallet forks? I need to be able to move small units of lumber, in the 750-1000 lb range, and am afraid the B3030 will not be able to handle it. I also need to be able to offload 1000-1800 lb trees from the nursery delivery truck, or my pickup or trailer, which I would also use the pallet forks for. Can a B3030 with a BH75 handle this, or do I just need to suck it up and move up to a Grand L with that big 723 FEL and BH90?
I've begun looking at the L3130, L3430, and now the L3830, but all for the sake of being able to move some lumber and trees around small residential construction projects. There were many times this past year that I was unable to move lumber units or offload trees with my little subcompact. It could drag stuff pretty well, but often times, it works a bit better to get things off the ground, or not have things come crashing down off a truck. /forums/images/graemlins/shocked.gif
I just don't want to get a B3030, and then end up realizing I need a Grand L a year later, just like I realized this little subcompact just can't do all the things I want. It sure would be nice to have one machine that could mow without really rutting the lawn, move new trees and some lumber around, and dig with a backhoe. It would be nice if I could buy a new machine, and actually be able to keep it for 15 years, rather than having to upgrade every couple of years. /forums/images/graemlins/confused.gif
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
Krause 8200 Cushion Flex Disc (A52349)
Krause 8200...
UNUSED FUTURE HYD HOSE BUNDLE (A51244)
UNUSED FUTURE HYD...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
2016 Ford Escape SE 4WD SUV (A50324)
2016 Ford Escape...
10 Ft Fork extensions (A50322)
10 Ft Fork...
