Is the B3030 enough tractor for me?
   / Is the B3030 enough tractor for me? #31
Maximum lift of the 403 loader is 1071 #. As far as wet heavy snow goe's, no tractor is going to move 500 ft. in a straight push, if you dump it off along the way, you will be ok.
   / Is the B3030 enough tractor for me? #32
Not to throw another question for you. But have you looked at the other brands. New holland/ Case and the deeres. I actually ordered a B3030 last summer and backed out of it and bought a case dx33. The main reason for me was the layout with the wife. But the other reason was what I am reading in this post on the machine bogging down under certain loads. When I did more research I found that the kubota had less horsepower at the Pto then the other Brands I mentioned. I have some very steep hills and run a sixty inch mmm. because Five foot was all I could spare in certain areas and this tractor has not bogged down yet so far at no matter what I have put it through. Hate to throw another opition at you but I shopped for at least three months and making up my mind over a tractor is mind boggling. Good luck in your choice.
Also When you do buy With what your wanting to do the B3030 is the smallest I would consider. Remember after the new wears off it is only time that you are in the seat and the more powerful the tractor the less time you will have to spend in it.
Doug.
   / Is the B3030 enough tractor for me? #33
One more post to add to the lifting capablities of the Kubota it is on the light side. I have several acres of trees and have lifted a lot of down trees with the Dx33 and it has no problem doing it. I chain them to the bucket and I use my chipper as ballast which weighs about 600lbs.
Also in response to bandit67's post in ruling out the larger case because of comparing it to the bx22 makes no sense. The larger tractors do not compare to your dx24e. I had a 595 deere which was very similar to your dx24e. and your dx24e would run circles around that deere. I had it equipped very much like you have yours. But that would not stop me from considering a larger deere. They are not in the same class as their larger tractors. Plus kubota has been making the bx22 for a long time and everyone else is playing catchup to that little tractor.
Doug
   / Is the B3030 enough tractor for me? #34
Hmmm....sounds like you're planning on doing many of the same things I do with my L4300. Most of the time I'm happy to have the HP. Sometimes I've wished I had more weight. Can't think of any time when I wanted less of either. Though I do understand about the creature comforts.
Is it enough? Probably most of the time it'll be adequate. As I recall, it's hilly around Honeoye. If you've got to pull that wagon of firewood up any grades, you'll need some weight...especially if there's wet leaves or a snow covering on the roadway.
If you had something like an L4400, an Ag tractor or even the old 8N waiting in the wings for those times when it isn't adequate, I'd say go for it. But if not, trading off raw capability for creature comforts seems like a poor trade. Creature comfort can be had in the easy chair in front of the TV. Finish the job quickly and you can be there /forums/images/graemlins/smile.gif.
On the other hand, if you've got time to putter and a cab on the B3030 (I know about western NY winters), I'm sure there's many enjoyable hours to be had.
Hope this didn't come off as overly sarcastic. I'm half seriously considering a B3030 with a cab myself....but it would be no-go if I didn't already have and intend on keeping the L4300.
Bob
   / Is the B3030 enough tractor for me? #35
Bob, are you saying an 8N will outpull a B3030. If I recall, the 8N has about 25 hp, and that from a gasoline engine. The 3030 is diesel and 30 hp. I have no idea about torque, but I suspect the 3030 has more, as well as 4wd.
I have owned 2 8Ns, one with a two range tranny. While neither one lacked for power in what I used them for, I wouldn't want to compare them to a modern tractor in pulling power. Please correct me if I'm wrong here. Maybe I just need to be shopping for an 8N instead of a compact.
   / Is the B3030 enough tractor for me? #36
</font><font color="blueclass=small">( Maximum lift of the 403 loader is 1071 #. As far as wet heavy snow goe's, no tractor is going to move 500 ft. in a straight push, if you dump it off along the way, you will be ok. )</font>
I dont see the 1071 lbs anywhere in my manual?
1) Lift cap. ( bucket bottom mid point)=882
2)Lift cap. (bucket pivot point, max hgt)=1091
3)Lift cap. (500mm fwd, max hgt)=782
4)Lift cap. (bucket pivot point, 1500mm high)=1356
5)Lift cap. (500mm fwd, 1500 mm height)=1025
(Page 4 of the LA403 manual)
   / Is the B3030 enough tractor for me? #37
Well, the 8N's heavier Teacha. Sometimes you need the weight. As I recall the 8N is a little over 3000 lbs bare, but I could be wrong on that. With filled rears it'd be closer to 4000 lbs. The 8N's got a low, wide stance as well; comforting on a grade.
Bare, the B3030 is under 1900lbs. With loader and filled rears it might hit 3000. The HP issue is moot, both have enough power.
The point is, Mr. Street has apparently been getting by OK to date with the 8N. If the wagon's heavy and the grade is steep, the 8N HAS been handling it. I've pulled heavy wagon loads numerous times with small tractors. On the level its OK, but on a grade the question becomes one of, "Who is pulling/pushing who?". It's not pleasant when it comes to that.
If the 8N's already in hand, is doing the work, and can be retained; a B3030 would be a safe enough bet. But if there's question of enough tractor and there will be only one tractor, then better an L3430, L3400 or an L4400 than either the 8N or the B3030 IMHO.
Bob
   / Is the B3030 enough tractor for me? #38
The 1071 #s is from the spec. sheet on the new b series brochure from kubota. For us the big factor is power in a light weight machine as our primary use is on grass! I also wanted a factory cab, however the big factor that kept me with kubota was the reliability and the indestructable construction of my B7500!
   / Is the B3030 enough tractor for me? #39
</font><font color="blue" class="small">( The 1071 #s is from the spec. sheet on the new b series brochure from kubota. For us the big factor is power in a light weight machine as our primary use is on grass! I also wanted a factory cab, however the big factor that kept me with kubota was the reliability and the indestructable construction of my B7500! )</font>
Ahhhh! OK. I saw the post and it just didnt "jive" with any numner in my owners manual...thats what had me stumped. Although I dont know why they put so many "modifiers" in the lift specs?? All they need to specify is about 2 different points and let it go..??
   / Is the B3030 enough tractor for me? #40
</font><font color="blue" class="small">( Also in response to bandit67's post in ruling out the larger case because of comparing it to the bx22 makes no sense. The larger tractors do not compare to your dx24e. I had a 595 deere which was very similar to your dx24e. and your dx24e would run circles around that deere. I had it equipped very much like you have yours. But that would not stop me from considering a larger deere. They are not in the same class as their larger tractors. Plus kubota has been making the bx22 for a long time and everyone else is playing catchup to that little tractor.)</font>
But how much longer has Case been making the DX33 than the DX24E - only a couple of years I thought? And that still doesn't change the fact that 2 dealers told me that they see more Case/New Hollands in the service dept than Kubotas, and they each sell twice as many Kubotas as CNH machines (and we're talking compacts). To me, that seems like a disproportionately higher number of warranty fixes for the CNH products than the Kubota. And shouldn't the smaller machines be overbuilt if the manufacturer is already building heavier duty larger machines? It would be nice to be able to get a new, larger red machine to match my implements, but I'm still gunshy about going with Case again - there are definitely some design flaws. Why wouldn't their experience with the larger compacts, if they have that much more experience, translate into better designs on the subcompacts?
I've also talked to a couple of JD 2210 owners that have worked their machines as hard or harder than I've worked mine, and they haven't had any problems. I'm not real familiar with the 595, but I don't think it was in the same class as the 2210 or DX24E. There are a lot of things I like about my machine, but it has also been slightly dissapointing.
Having to re-weld and add additional steel to strengthen the loader components due to failures related to the hydraulic strength (high) vs. the component strength (not high enough for the hyd. strength) comes down to design flaws that the engineers should have been able to forsee. The fact that CNH doesn't seem to care, as evidenced by their not responding to my emails to customer service tells me that I should look elsewhere next time. Why should my dealer be responsible for paying to fix the manufacturer's design flaws?
Sorry, but just typing this response has reconfirmed my decision to look at other manufacturers with better established reputations in the compact arena.
2014 FORREST RIVER SALEM TRAVEL TRAILER (A50854)
2014 FORREST RIVER...
TC710 FINISHING MOWER (A50459)
TC710 FINISHING...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
Woods 3180 Batwing Mower (A50514)
Woods 3180 Batwing...
2004 KENWORTH BUCKET TRUCK(INOPERABLE) (A50854)
2004 KENWORTH...
1987 FORD 2110 TRACTOR (A51222)
1987 FORD 2110...
