is it necessary?
/ is it necessary? #1
accordionman
wright city, mo.
KUBOTA L3000DT, FEL.
HELLO TO ALL,
i will be welding on my FEL bucket, and i want to know if
it is necessary to disconnect the battery on my tractor.
appreciate any, and all feedback.
accordionman
william l. brown
/ is it necessary? #2
I think the answer is yes. Is it a must????? Not sure but if it only takes a couple minutes it's better to be safe than poorer after having to fix whatever may have happen. /w3tcompact/icons/wink.gif/w3tcompact/icons/smile.gif
Darin
/ is it necessary? #3
William, I seem to recall a thread from a long time ago (that I could probably never find) about welding on tractors and damaging rod bearings (I won't even try to give the technical, scientific description of what happens, but there are some other guys on here who can). At any rate, first choice is to have the loader or bucket (or whatever you're going to weld on) removed from the tractor to do the welding, second choice is to disconnect battery cables, and third choice is to just have your ground clamp as close to the spot you're welding as possible. And I used the third choice when I welded on mine./w3tcompact/icons/laugh.gif
/ is it necessary? #4
IS IT NECESSARY? no. but i wont hurt to do it. also depending on where exactly u are welding watch the heat, it can cook fluid and seals very quick. i wish i would always follow my own advise/w3tcompact/icons/frown.gif
/ is it necessary? #5
I work in a chemical plant and see pump bearings and instrumentation get fried 2-3 times a year due to poor grounding techniques when welding. Ditto what Bird says...establish a very good ground as close to the weld as possible...and be sure the electrical path does not go through sensitive things such as bearings.
RET
UNUSED ATS POWER ATS-MIG-140 MIG WELDING MACHINE (A64281)
UNUSED ATS POWER...
3pt 6 Row Cultivator (A64119)
3pt 6 Row...
2017 Caterpillar 349FL Hydraulic Excavator (A61572)
2017 Caterpillar...
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
KUBOTA 48" PIN ON BUCKET (A64280)
KUBOTA 48" PIN ON...
159119 (A60430)
159119 (A60430)
