Is it just me...
   / Is it just me... #31
I really only have trouble with one of my implements, the 96" box blade. It's not that hooking it up is a problem, it's taking the stupid thing off.
The pins have no head on them and sometimes require a pipe wrench to turn them to remove the linch pin.
Weld something onto the pin so you can turn it.
Or get a short 1 1/8 diameter cat 2 pin.
   / Is it just me... #32
I would have replaced those headless pins immediately with a hitch pin of the right size, with a handle.
I would but look at the first pic again. These have a shoulder or step down. Where the lift arm connects is larger than the end the linch pin goes on. It is a very silly design IMO.
   / Is it just me... #33
I would have replaced those headless pins immediately with a hitch pin of the right size, with a handle. They come in many sizes. For example: GRAINGER APPROVED VENDOR Hitch Pin,Std,Stl,Zinc,1x7 3'/'4 L - Hitch Pins - 3HLR5'|'3HLR5 - Grainger Industrial Supply Bruce
Bruce, those are CAT 1 / CAT 2 pins with two different diameters. Have the same on my Bush Hog 3008 cutter.
If you raise or lower 3 point just slightly you can get pressure off of the pin and it will rotate and can be easily removed. Repeat on other side. Takes a minute or two at most.
Sent from my iPad using TractorByNet
   / Is it just me... #34
Yes I need to weld something on the end. It's one of those things you don't think about when you have time to do it.
Btw... This is a Bushhog brand, made by Dirtdog, and unless they have changed the design I would never buy another.
   / Is it just me... #35
The design is so it can be pulled by a cat 1 or cat 2 tractor.
This is the pin that does it.
   / Is it just me... #36
The design is so it can be pulled by a cat 1 or cat 2 tractor. <img src="http://www.tractorbynet.com/forums/files/attachments/398643-just-me-47711-jpg"/>
Like I said it is silly. Show me a cat1 machine capable of really using a 96" box blade.
   / Is it just me... #37
How about a single diameter hitch pin with a hitch pin bushing on it-loose or welded?
Or a short, single diameter Cat 2 pin that only goes through the section you use? Put the lock pin where the Cat 1 section is.
Bruce
   / Is it just me... #38
How about a single diameter hitch pin with a hitch pin bushing on it-loose or welded? Or a short, single diameter pin that only goes through the section you use? Put the lock pin where the cat 1 section is. Bruce
That still does not solve the problem if you are trying to just lower the 3 point to the ground a beat the **** out of the pins with a sledge hammer.
If you adjust 3 point height to get pressure off of the pins, they come out easily.
   / Is it just me... #39
Here is my 60" wide, cat1 Toolcat with a 96" box blade.
   / Is it just me... #40
How about a single diameter hitch pin with a hitch pin bushing on it-loose or welded? Or a short, single diameter Cat 2 pin that only goes through the section you use? Put the lock pin where the Cat 1 section is. Bruce
On the box blade only the outside hole is larger, the two inner holes are smaller.
I honestly did not think about small pin with a welded bushing. I'll look at that tomorrow!
2015 CATERPILLAR 573C FELLER BUNCHER (A51242)
2015 CATERPILLAR...
CASE TV370B SKID STEER (A51242)
CASE TV370B SKID...
2017 Buick Encore SUV (A50324)
2017 Buick Encore...
2021 CATERPILLAR 303E CR EXCAVATOR (A51242)
2021 CATERPILLAR...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
