Is it just me...
   / Is it just me... #31
I really only have trouble with one of my implements, the 96" box blade. It's not that hooking it up is a problem, it's taking the stupid thing off.
The pins have no head on them and sometimes require a pipe wrench to turn them to remove the linch pin.
Weld something onto the pin so you can turn it.
Or get a short 1 1/8 diameter cat 2 pin.
   / Is it just me... #32
I would have replaced those headless pins immediately with a hitch pin of the right size, with a handle.
I would but look at the first pic again. These have a shoulder or step down. Where the lift arm connects is larger than the end the linch pin goes on. It is a very silly design IMO.
   / Is it just me... #33
I would have replaced those headless pins immediately with a hitch pin of the right size, with a handle. They come in many sizes. For example: GRAINGER APPROVED VENDOR Hitch Pin,Std,Stl,Zinc,1x7 3'/'4 L - Hitch Pins - 3HLR5'|'3HLR5 - Grainger Industrial Supply Bruce
Bruce, those are CAT 1 / CAT 2 pins with two different diameters. Have the same on my Bush Hog 3008 cutter.
If you raise or lower 3 point just slightly you can get pressure off of the pin and it will rotate and can be easily removed. Repeat on other side. Takes a minute or two at most.
Sent from my iPad using TractorByNet
   / Is it just me... #34
Yes I need to weld something on the end. It's one of those things you don't think about when you have time to do it.
Btw... This is a Bushhog brand, made by Dirtdog, and unless they have changed the design I would never buy another.
   / Is it just me... #35
The design is so it can be pulled by a cat 1 or cat 2 tractor.
This is the pin that does it.
   / Is it just me... #36
The design is so it can be pulled by a cat 1 or cat 2 tractor. <img src="http://www.tractorbynet.com/forums/files/attachments/398643-just-me-47711-jpg"/>
Like I said it is silly. Show me a cat1 machine capable of really using a 96" box blade.
   / Is it just me... #37
How about a single diameter hitch pin with a hitch pin bushing on it-loose or welded?
Or a short, single diameter Cat 2 pin that only goes through the section you use? Put the lock pin where the Cat 1 section is.
Bruce
   / Is it just me... #38
How about a single diameter hitch pin with a hitch pin bushing on it-loose or welded? Or a short, single diameter pin that only goes through the section you use? Put the lock pin where the cat 1 section is. Bruce
That still does not solve the problem if you are trying to just lower the 3 point to the ground a beat the **** out of the pins with a sledge hammer.
If you adjust 3 point height to get pressure off of the pins, they come out easily.
   / Is it just me... #39
Here is my 60" wide, cat1 Toolcat with a 96" box blade.
   / Is it just me... #40
How about a single diameter hitch pin with a hitch pin bushing on it-loose or welded? Or a short, single diameter Cat 2 pin that only goes through the section you use? Put the lock pin where the Cat 1 section is. Bruce
On the box blade only the outside hole is larger, the two inner holes are smaller.
I honestly did not think about small pin with a welded bushing. I'll look at that tomorrow!
2025 GIYI Dual Cylinder Hydraulic Grapple Plate Bucket Skid Steer Attachment (A50322)
2025 GIYI Dual...
2014 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2014 Ford F-450...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2008 VOLVO VNL670 SLEEPER (A51219)
2008 VOLVO VNL670...
1973 CATERPILLAR 988 LOADER (A51222)
1973 CATERPILLAR...
2022 CATERPILLAR 305CR EXCAVATOR (A51242)
2022 CATERPILLAR...
