Forks is is there anything I can't do with these
   / is is there anything I can't do with these #21
No. ... OP musta spilled his periods.
   / is is there anything I can't do with these #23
From the looks of that picture you supplied,
you can't rake leaves with them.:p
   / is is there anything I can't do with these #25
You might be able to hook on to a pallet, and use that to smooth out your driveway... heck I guess you scoop up a little gravel that way.:D
I moved a lot of snow with a pallet on a forklift. It helped to have about a ton of steel on it for better traction while feathering the tilt.
   / is is there anything I can't do with these #27
Recently I had to load a bunch of 10' lengths of old cut up well casing pipe. Chaining or grappling didn't work out. I ended up picking up two at a time by sliding the forks into the ends of the pipe and lifting them that way. Much quicker.
   / is is there anything I can't do with these #28
Very handy for adding wood to the fire.
   / is is there anything I can't do with these #29
And you can then push from farther back when you have the pipe extensions on...
I like the foot pegs for the passenger on the side....makes it safer when picking fruit.
2010 Ford Transit Connect Cargo Van (A53422)
2010 Ford Transit...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A57024)
2-Row Peanut...
3 WHEEL ELECTRIC GOLF CART (A55745)
3 WHEEL ELECTRIC...
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
2017 VOLVO EC160EL EXCAVATOR (A52707)
2017 VOLVO EC160EL...
Komatsu WA180-1 Wheel Loader (A47477)
Komatsu WA180-1...
