Forks is is there anything I can't do with these
   / is is there anything I can't do with these #21
No. ... OP musta spilled his periods.
   / is is there anything I can't do with these #23
From the looks of that picture you supplied,
you can't rake leaves with them.:p
   / is is there anything I can't do with these #25
You might be able to hook on to a pallet, and use that to smooth out your driveway... heck I guess you scoop up a little gravel that way.:D
I moved a lot of snow with a pallet on a forklift. It helped to have about a ton of steel on it for better traction while feathering the tilt.
   / is is there anything I can't do with these #27
Recently I had to load a bunch of 10' lengths of old cut up well casing pipe. Chaining or grappling didn't work out. I ended up picking up two at a time by sliding the forks into the ends of the pipe and lifting them that way. Much quicker.
   / is is there anything I can't do with these #28
Very handy for adding wood to the fire.
   / is is there anything I can't do with these #29
And you can then push from farther back when you have the pipe extensions on...
I like the foot pegs for the passenger on the side....makes it safer when picking fruit.
2016 MACK CXU613 MID-ROOF SLEEPER (A55745)
2016 MACK CXU613...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
PALLET OF 2" X 4" STEEL TUBING & SITE PANELS (A54757)
PALLET OF 2" X 4"...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
PALLET OF (2) HEATERS (A55745)
PALLET OF (2)...
2025 Swict 84in Bucket Skid Steer Attachment (A53421)
2025 Swict 84in...
