Forks is is there anything I can't do with these
   / is is there anything I can't do with these #21
No. ... OP musta spilled his periods.
   / is is there anything I can't do with these #23
From the looks of that picture you supplied,
you can't rake leaves with them.:p
   / is is there anything I can't do with these #25
You might be able to hook on to a pallet, and use that to smooth out your driveway... heck I guess you scoop up a little gravel that way.:D
I moved a lot of snow with a pallet on a forklift. It helped to have about a ton of steel on it for better traction while feathering the tilt.
   / is is there anything I can't do with these #27
Recently I had to load a bunch of 10' lengths of old cut up well casing pipe. Chaining or grappling didn't work out. I ended up picking up two at a time by sliding the forks into the ends of the pipe and lifting them that way. Much quicker.
   / is is there anything I can't do with these #28
Very handy for adding wood to the fire.
   / is is there anything I can't do with these #29
And you can then push from farther back when you have the pipe extensions on...
I like the foot pegs for the passenger on the side....makes it safer when picking fruit.
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A55851)
2010 Turfco...
2018 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2018 ALLMAND BROS...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
2025 Swict 84in Bucket Skid Steer Attachment (A53421)
2025 Swict 84in...
