Forks is is there anything I can't do with these
   / is is there anything I can't do with these #21
No. ... OP musta spilled his periods.
   / is is there anything I can't do with these #23
From the looks of that picture you supplied,
you can't rake leaves with them.:p
   / is is there anything I can't do with these #25
You might be able to hook on to a pallet, and use that to smooth out your driveway... heck I guess you scoop up a little gravel that way.:D
I moved a lot of snow with a pallet on a forklift. It helped to have about a ton of steel on it for better traction while feathering the tilt.
   / is is there anything I can't do with these #27
Recently I had to load a bunch of 10' lengths of old cut up well casing pipe. Chaining or grappling didn't work out. I ended up picking up two at a time by sliding the forks into the ends of the pipe and lifting them that way. Much quicker.
   / is is there anything I can't do with these #28
Very handy for adding wood to the fire.
   / is is there anything I can't do with these #29
And you can then push from farther back when you have the pipe extensions on...
I like the foot pegs for the passenger on the side....makes it safer when picking fruit.
2010 John Deere TX Gator 4x4 Utility Cart (A55973)
2010 John Deere TX...
2012 PETERBILT 365 (A55745)
2012 PETERBILT 365...
1990 TRAIL MASTER TRANSPORT TRAILER (A55745)
1990 TRAIL MASTER...
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A53421)
2007 Godwin Pumps...
2022 WESTERN STAR 49X TRIAXLE (A55745)
2022 WESTERN STAR...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
