Is Brian still around?
/ Is Brian still around? #61
And on the matter of Everlast Welders. In my opinion Mark is a valued contributor to TBN.
I find his posts to be unbiased and better than one would expect from a sponsor.
I know he has helped a lot of guys on here (including me) with questions concerning Everlast welders.
I don’t own an Everlast for reasons that are irrelevant to this discussion but I can say that I have gained much knowledge from Mark’s posts.
Perhaps he set the bar too high for guys like “Brian”??
/ Is Brian still around? #62
I'm reluctant to believe the tank theory. 100lbs on the left rear tire isn't going to have much effect.
To test this simply add air pressure to the left rear tire. If you can level your bucket by adding a few lbs of air pressure, less than 5psi, then simply run your tires that way.
Curious to hear the result.
Or stand on one side of the platform vs the other (ok, perhaps not all of us, but 90% of us on here weigh more than 124# with boots and outdoor gear on).
If that makes a difference, the rear tires are WAAAAAAY low on air.
Aaron Z
I weigh almost 220 at 6’. Because I respect the person at RK that sold me the tractor I’m going to see if it makes a difference. I’m not an engineer, I’m not a mechanic, heck I’m not even that good at repairing stuff. But I have a horse farm and I know that I depend on my tractors and I want my bucket level.
I guess I opened a can of worms. Lol
/ Is Brian still around? #65
I'd say if you park your tractor on level ground, like in a garage, and measure the distance from ground to the bottom of the left rear axle just inside the tire, and do the same for the right side, those numbers should be the same. Then do the same for the front end.
If both rear numbers or both front numbers aren't the same, check tire inflation and adjust them to get the same numbers.
If both rear numbers are the same and both front numbers are the same, yet the loader bucket can't lay flat across the leading edge and back of the bucket, the loader is uneven. Then you'd have to figure out if it's a mounting issue or a manufacturing issue and proceed from there as to who's gonna pay for it/remedy it.
Of course, that's assuming the axles are the same dimensions on both ends. Always the assumptions. :laughing:
/ Is Brian still around? #66
Just sent you a PM
Well to laugh at one idea over another when nothing has fixed the issue seems a little presumptuous.
/ Is Brian still around? #68
If the fuel tank weight issue is causing it, and you try and compensate with tire inflation, what happens when the tank gets down to low? The FEL is going to tilt back.
Of course it will. I offered that to see if slight chassis tilt was causing the problem. It's not. But it could be disproved by altering tire pressure.
/ Is Brian still around? #69
Wow. The thread title looked interesting and I wanted to know who 釘rian was. Thought maybe it was the real name of a popular member that had passed.
Had to read almost 40 posts to understand what was going on and what the heck è¿*K was. I was determined to figure it out without having to ask an explanation that was so obvious to everyone else. I知 still unsure of what make tractor is even being discussed. LOL
ANYHOW the fuel tank explanation is the dumbest thing I致e ever heard of IMO. Carry on...
Rural King Farm and Home stores started purchasing tractors from TYM, rebadged to RK, and selling them out of their stores.
/ Is Brian still around? #70
You caught up amazingly fast Terry. :D
/ Is Brian still around? #71
/ Is Brian still around? #73
I thought TYM was manufacturing to RK's specs. I wouldn't consider that a rebadge if it's custom work. Kinda like when Deere has Yanmar build them tractors. I don't consider them rebadged Yanmars, I consider them Deeres.
/ Is Brian still around? #74
I guess it all comes down to semantics ... since TYM is the actual manufacturer, it depends on how you look at it if you call it "custom" or "re-branded". Either way, RK is not selling a tractor they make - they are having it built by a maker who also sells their own brand under their own name.
As to "reps" being on TBN - I guess that all depends on how it is viewed. The guy who owns CycleStop is also on this forum. He is not on here as a rep for his company but often offers comments on threads that have to do with wells ... however, when he does, he is at times roasted because he gets accused of "shilling" for his company since his product will solve the issue a person is having.
/ Is Brian still around? #75
We have several frequent posters that also sell product. It's very easy to spot the ones that are "pimping" their product versus the ones who are simply offering advice. I would hope the guy you mention continues to offering advice and ignores those who misinterpret his intention.
/ Is Brian still around? #77
Sad and distressed to confirm: a contact from RK has informed me that "Brian is no longer with the company..."
Unlike other brands, we were blessed to have an "official voice of authority" about RK Tractors.
/ Is Brian still around? #78
I almost pitty the guy who comes on here and tries to pick up where the other 2 RK guys left off.
/ Is Brian still around? #80
More importantly....... will another RK guy even try to "pick up" where they left off?
2022 CATERPILLAR D3 CRAWLER DOZER (A65053)
2022 CATERPILLAR...
2005 MACK CXN613 6X4 T/A  DAY CAB TRUCK TRACTOR (A67147)
2005 MACK CXN613...
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
2018 Ford F-550 Altec AT37G 37ft. Insulated Bucket Truck (A64556)
2018 Ford F-550...
New/Unused Wolverine 43in Mini Rock Bucket (A65583)
New/Unused...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
