Is anyone here familiar with scaffolding?
   / Is anyone here familiar with scaffolding? #81
You will NOT find me on that kind of scaffold or that high up. I can't even begin to imagine the time and difficulty in setting that up, lifting the pieces into place and then still not having a complete platform to stand on.
And then there's the weight. OP wants to set something up on a deck that looks to be elevated by some height. You'd be adding considerable weight on top of the deck.
It still looks like you have to climb straight up, which I cannot do.
I don't like heights. I don't like ladders, and I don't like walking roofs. If I'm going to do a job, I find scaffolding makes me the most comfortable. It doesn't wobble, so I don't get the moments I sometimes get on a ladder where the ladder starts shaking and my knees start shaking and it's hard to make it stop.
The safest way up is to use a ladder. I find that if I climb on the inside, with at least one plank on every level, I feel very protected.
You should consider the Hardie boards as a replacement as long as it's only appearance and not structural. They're impervious to most every thing and holds paint very well.
I was actually considering Trex - I will look into Hardie and compare/contrast. THANK YOU,
   / Is anyone here familiar with scaffolding? #83
Here's the way I do it:
First level is on the ground, you do it standing on the ground.
Second level is only five feet off the ground, you do it standing on the ground too. I might have to climb about a foot to get the braces on.
Third level, the top of the second level is at ten feet. I put a plank at six feet, this is easily done from the ground. Then I lean all of the components for the third level against that plank, and climb up onto it. I'm safe and secure, with a cage on four sides at mid-chest height. I pick up the pieces that are leaning against the plank and put them in place, also at mid-chest height.
For four or more levels I use ropes. The key is "ropes," plural. I stack all of the components for one level on the inside of the scaffolding, and put a rope on each one. That way it's one trip up and down for each level. I put two planks four feet below the top, with a gap between them of about 8", and pull everything thing up through the middle of the scaffold through that gap. The whole time I've got a cage around me on all four sides and two planks under my feet. The 5' scaffold sections are only about 40 pounds and I'm only lifting them to mid-chest height so it doesn't feel sketchy at all.
I've also set up the more common 6'8" sections by myself and that is a lot scarier. They're heavier, they're top-heavy, and you have to lift them a lot higher, up over your head. That's why I bought the 5' sections.
Let me offer one more tip for when it's time to take it down: If you lower a section using a doubled loop of rope, you can let go of one end and pull the rope back up. That way you can lower everything down without ever having to go down the scaffold. For things like planks and braces that you can't easily loop a rope around, I go up with a bunch of short pieces of rope and tie a loop to them for lowering.
If you tie one end of the rope to the scaffold you only have to hold half the weight. The scaffold frames I use are only 40 lbs but that way I only have to hold 20 lbs. Plus you feel a lot more secure with one end tied off.
Work smarter not harder - I like that!
   / Is anyone here familiar with scaffolding? #86
I'm late seeing this scaffolding post, but for our new horse stable I bought scaffolding because I had lots of projects, lights, fan, etc.
I also bought stabilizer outrigger wheels that can easily be adjusted (out,in,sideways). Of all places I bought mine from Walmart online.
It's 24 feet up to the fan, base of roof cupola.
Floor is level concrete, I don't know how it would work outside on grass, I don't think it would well unless it was on level, probably on plywood.
For me it's worked well even with two 220# guys working on top platform.
View attachment 758764View attachment 758765
I like those folding outriggers - something else to look for! 😁👍
   / Is anyone here familiar with scaffolding? #89
   / Is anyone here familiar with scaffolding? #90
Today I had to take down a section of scaffolding where I had been repairing a rotten fascia board. It was three frames high with a guardrail. Standing level 16 feet off of the ground. I used a rope for the guardrail and the top frame, then the other two frames I got from the ground. One trip up the scaffold and one trip down.
I timed myself: 22 minutes to get everything on the ground.
Frontier 3 Point 8' Disk Harrow, S/N 1XFDH13XVK002234, 22" Disks, Asset# 64 (A59076)
Frontier 3 Point...
Quick Coupler (A57149)
New/Unused Self Dumping Hopper (A57454)
New/Unused Self...
PALLET OF CARBURETORS & PARTS WASHER (A58374)
PALLET OF...
2023 Polaris Ranger SP 4x4 Utility Cart (A55787)
2023 Polaris...
MILITARY  BED TRUCK (A58214)
MILITARY BED...
