is a rotary plow useful?
/ is a rotary plow useful? #1
Charlesaf3
Veteran Member
Richmond VA & Irvington VA
Kubota B3030, Kubota M59 TLB
I have a gravely rotary plow that I've never used. I also have a gravely rototiller head, which I do use. Is there anything the plow is better than the rototiller for?
/ is a rotary plow useful? #2
The rotary plow will prepare as loose a seedbed as I've ever seen. It is an amazing implement.
It can also be used to plow ditches, too.
The tiller attachment is just a different creature for cultivation once the grown is broken up with the plow.
hmm, can see the ditches, might have to try that on a project I'm doing now (granite edging). Probably would justify it right there.
Tiller has done a good job of initial cultivation, to the point that I wondered if it basically replaced the plow in the gravely arsenal
/ is a rotary plow useful? #4
The tiller was never designed to break up virgin ground for flowerbeds, gardens, etc. That is what the plow is for.
/ is a rotary plow useful? #6
When I used the rotary plow on unbroken ground I didn't have to go over the same ground with a tiller (I had both). I used the rotary plow and planted. I didn't mount the tiller until the plants were up and the weeds that came with them.
/ is a rotary plow useful? #7
You are missing out on something special. If you think the plow is good, run the cultivator through your garden just before planting. Use a high PTO RPM and a low ground speed - while traveling backwards. You will sink to your ankles in soft fluffy soil.
/ is a rotary plow useful? #8
yea the soft soil is nice to plant in but when it rains its harder than concrete.
