Is a dually needed?
/ Is a dually needed?
thanks. no mods for me;other than a tan pinstripe and some mud flaps.
well, not until the warranty is long over. hard to believe I'd need more than the current ratings.
this truck came with Korean Nexxen tires, which are pretty unknown, but likely a better tire than the General Ameritechs that are oem simply because they
are the cheapest tire on the market. With horrible reviews at tirerack.com. Well, if I don't like the Nexxens, there is always Michelin but I don't think I'll swap them out to start, unless any of you have had the Nexxens with really poor results.
/ Is a dually needed? #263
Congrats, modding a truck is an addiction, probably worse than acquiring tractors and associated toys, er tools.
Which trans did you get? I hope the Aisin
/ Is a dually needed? #264
Congratulations on the new truck! ATM lanes can be a challenge. When you tow that 5th wheel, get your rig straight with the toll booths too. :) With my 8' wide rack-side bed, I run with the mirrors folded out all the time.
thanks. yes, it seems almost a standard add. Ran fine, seemed a little slow to get moving, a little bog but a lot of weight to get moving even with 4.10 gears. I was all set to see the tach at 2500 or something with those gears but no way, looks like about 1900 rpm at 62mph. Will be curious to see what rpm it runs at 70 in case I'm unloaded. Now the question is will the torque of this motor, which is about double the torque of my previous Ford V10 gasser, will it hold the top one or two gears without a sweat under load? Hoping it will, particularly if I'm only pulling eight tons.
something else I found interesting. Passenger side center intrusion into foot space was serious. That engine/trans under there really hogs up some room, the floor foot well is deep but not too wide. Nice steering wheel, easy to read buttons, all seemed nicely laid out. Standard inverter for AC, but no Ram boxes, bummer. All that wasted space in those huge fenders back there.
/ Is a dually needed? #266
One thing you'll notice is the powerband of the Cummins and specifically the torque that's available all across it. The Cummins, and diesels in general, tow dramatically different from a gasser. The days of downshifting on grades are pretty much over for you...just the purr of the Cummins and the turbo singing to you a bit.
/ Is a dually needed? #267
turbo has to spool, so there might be a little lag there (haven't driven a new dodge).
depends a lot on the road, but on the interstate it should
that big downpipe/exhaust has to run somewhere
i find i use that space, personally i wouldn't want those boxes i think they are ugly too. but if you think it's a bummer then it's a bummer
i find i use that space, personally i wouldn't want those boxes i think they are ugly too. but if you think it's a bummer then it's a bummer[/QUOTE]
I just think not using that space for something worthwhile, even if accessed from the inside, is well, a waste of space... Extra fuel tanks?
/ Is a dually needed? #269
From the owner " cheapest tires , slow out of the gate " My other brand came with Michelin tires, turns 1800 at 70 MPH also sunroof, nav, heated and cooled seats for same amount of money.
Compare all brands before writing 50K + check.
actually I was complimenting, I think, this truck because it did not have the cheapest tires. It just had a brand unknown to me, but South Korea makes very good tires with very good quality control. Kumho for example makes great trailer tires. I usually swap out all my car and truck tires, usually with Michelin, but I'm curious to see how these work out. Sure wish TireRack would include them.
as far as acceleration, I got in to this thing from my toyota avalon, which has a non linear accelerator; i.e. press down twenty percent and get thirty percent in return. Needs a gentle touch. The Ram seems much more linear, when I put my foot in it, we truly surged forward. I was still learning my clearances so I wasn't exactly doing bootleg turns with it, but it ran fine. And was pretty quiet too. More steering effort than I expected; again coming out of a very low effort car, but my suburban has easier steering. I really liked the fact that I could read the controls easily, unlike GM.
I think I have read every review every written on the big three HD truck brands. Although not the offroad stuff, no interest in it.
I honestly think they are all good and all more than I need. The last Dodge I had was an Intrepid company car, when all the other guys had Tauruses.
Boy they liked that Intrepid when it came in, much roomier inside and the base engine had more guts than the Ford plus it handled better. That model did have some issues, including an entire new V6 engine in the first two weeks. I did the fleet buying for the company and I must have bought a dozen Tauruses over the years. But no trucks, which is why I've asked all these questions.
and yeah, I clipped a curb, just a little curb. :ashamed: I'm sure it hurt my pride more than it did that tire. In my defense we were coming out of an overflow parking lot that only the dealer car parkers used, so boy clearance was tight. Swing out, swing out...
/ Is a dually needed? #271
<snip>
Curbs were meant to be run over. The other alternative is creaming something on the other side.
/ Is a dually needed? #272
From the owner " cheapest tires , slow out of the gate " My other brand came with Michelin tires, turns 1800 at 70 MPH also sunroof, nav, heated and cooled seats for same amount of money. Compare all brands before writing 50K + check.
Daugen,
congrats on the truck you'll love it. I just ordered a ram 5500 with 204" frame for a 3 rd box truck for my company. I have had absolutely great service from all of my rams. I don't know what part of NC you might be moving to but I can tell you the best dealer I have ever dealt with for rams if you're interested.
NC Redneck,
Ever heard of torque management? These trucks aren't built to drag race or burn the tires off of. How about you congratulate the man like everyone else and quit being such a child.
/ Is a dually needed? #273
Come on, man...
He bought the truck, he likes the truck, be happy for him and wish him well.
Daugen, nice rig!
Fordman and others, thanks. If I were staying where I am, a dually would be impossible. But I'm moving to a farm, will have no problem parking it there, under cover, and for the occasional trip to Home Depot or the Kubota dealer, well except for backing a semi into a loading dock (I did that once and boy did I embarrass myself in front of the "real" drivers" who patiently watched while I jerked around...) I shouldn't have a problem navigating with it.
I still have my one Head West trip to finish. And if I'm going to pull a trailer through the Rockies, after all the effort of driving that gas motorhome through the Eastern mountains, I felt I sure err on the side of mass and get the "bigger" one. Well one thing for sure, as scarce as these things are used around here, if I ever don't like and want to sell it, there should not be any problem there.
I was surprised that the holes in the truck bed for the fifth wheel hitch were not covered. Just left open for leaves and junk to get in. I'm going to get a hard folding tonneau cover for it, had a BakFlip once and liked it, but now there are lots of competing brands. That, some big mudflaps, door steps, and a nice tan pin stripe and I should be good to go. the truck was filthy when I saw it, hopefully it will clean up nicely. white is, well, white...
Hmmm, this must be the biggest hitch size, off to get another part. 2 5/16 instead of 2? Getting a good collection of hitch balls; I use both the smaller sizes, not sure if I'll use the biggest. The whole point of towing something heavy in this truck was to use the fifth wheel, or a gooseneck hitch for an equipment trailer.
will need another big drop down; like the suburban the receiver is way up there.
doesn't look like any way easy to climb up into this bed. Yes NC/Scott, GM has some nice features, like those steps in the bumper. Ford had that swing out step, I guess Ram thinks I'm sprier than I am...oh well,if I need a little step ladder, I'll carry it.
guys, I think NC/Scott was just trying to watch my back, not bash. The problem is that equipment levels can vary hugely on these things so comparing pricing isn't so easy. Mine does not have a sunroof, nor did I want one. I literally never use it, so why have the complexity and the weight? though weight isn't much of an issue here for sure.
so far, I think I'm headed to the Greenville-Washington area of the Inner Banks NC. Two Ram dealers, checked that out, plus a Kubota and John deere. What more could a guy want? :D
/ Is a dually needed? #276
<snip>
<snip>
I highly recommend the "Cosco" [NOT Costco] brand from HD, etc. Aluminum, light, folds easily, locks when unfolded, fairly sturdy. I try to keep one with the truck at all times.
thanks newbury. I'll check it out. the really nice lightweight one I bought for my motorhome is just silly big, need a three footer.
It might be the same brand. Nice finish, very lightweight but felt strong. As an ex fireman, I like good ladders...
Now wouldn't it be nice if Ram used that big open dually fender space for a swing out ladder that folded down to the ground.
of course I could always install a hydraulic lift on the back...:D
sadly I'm not kidding. I'm sitting here about to go field mowing with braces on both my wrists, a soft collar on and a back brace.
Leaping up onto pickup beds that are very high is something I did with ease thirty years ago. Now it looks like a mountain.
That little ladder will do nicely I'm sure. And fit on the floor in the back seat if I keep it clean.
the fields are calling, have a great weekend.
/ Is a dually needed? #278
<snip>
of course I could always install a hydraulic lift on the back...:D<snip>.
I prefer the "loose" ladder, right now it's in my shop being used as a step ladder to access molding on an 8' ceiling.
/ Is a dually needed? #279
Yea, my F350 came with BFG A'S and at 1900 rpm it runs 79 mph but I have 3.73 gears.
Chris
2015 KUBOTA F3990 MOWER (A66091)
2015 KUBOTA F3990...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2018 Jeep Grand Cherokee Trackhawk 4x4 SUV (A64557)
2018 Jeep Grand...
2019 JOHN DEERE 331G SKID STEER (A65053)
2019 JOHN DEERE...
2026 DEVELON DX27Z-7-US30 EXCAVATOR (A65053)
2026 DEVELON...
2022 EZ-GO ELITE...
