International 504
/ International 504 #1
retiredrich
Ashland, NE
1965 International 504
Hi, I'm new here. I just bought a 504 and have a question about the hydraulics. There is a large square plug on the floor board left of the transmission shifter. I removed it and you can see the transmission gears. Is this also the reservoir for the hydraulics that the loader etc. uses? If it isn't, where is the reservoir? Thanks
/ International 504 #2
Yes, that is it. Approx 1 1/2"plug, and have a 3/4" square hole. It is both the hydraulic, and trans. oil filler, ie: transdraulic fluid. Hytran, or comparable...
The check plug should be on the left side, near the clutch linkage. Guessing a 3/8" or 1/2" plug.
I have a service manual here that covers several models. It shows the trans/hyd capacity at 13 gallons.
It also mentions in my loader manual, to check fluid level with cylinders retracted.
