Intermittent Starter
/ Intermittent Starter #21
The easiest way to troubleshoot it is to remove it from the tractor, mount it up in a vice and hit it with jumper cables, preferrably a battery charger. That will eliminate everything but the starter/solenoid and you can make repairs and test a lot faster. Every hit with 12v should pull the sol and spin the starter.
/ Intermittent Starter #22
Could it be a bad ground ? I don't see that you have checked this. Although you may measure the correct voltage you may not have enough current.
Rich
I have had this problem on a car--manifested as a dead battery. The ground to the alternator was loose. Only took the shop replacing the battery, then when that didn't work replacing the alternator. That worked as they replaced the ground wire.
Caterpillar C18 Industrial Diesel Engine - Serial N8F01120 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
2018 Chevy Traverse 3rd Row Seating (A63689)
2018 Chevy...
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
2013 Ford F-350 4x4 Crew Cab Knapheide Service Truck (A61573)
2013 Ford F-350...
2020 BOBCAT E50 EXCAVATOR (A64279)
2020 BOBCAT E50...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
