Intermittent Failure
/ Intermittent Failure #1
JimBoy
Ossining, NY
John Deere 3720
Hi all. I have a JD3720 with a backhoe. The last two times I started the tractor, the left stabilizer would not raise. The lever would not move in that direction. After about 20 minutes, it would work. What is going on?
/ Intermittent Failure #2
water/ice in the system is a guess...
If that is the case, do I need to flush the entire hydraulic system?
/ Intermittent Failure #5
Most of the time it is water in the spring cup or in the linkage system, not in the hydraulics. Your system would have to be in BAD shape for a valve spool to freeze up. Personally I have never seen it. Almost all the time it is the detent or spring center cup on the back of the spool [opposite the linkage hook up] that has water in it. CJ
/ Intermittent Failure #6
I totally agree with this....
2016 Chevrolet Express Shuttle Bus (A66736)
2016 Chevrolet...
2014 CATERPILLAR D6T XL HI- TRACK CRAWLER DOZER (A65056)
2014 CATERPILLAR...
2014 Ford Focus Hatchback (A66738)
2014 Ford Focus...
2020 FREIGHTLINER M2 4X2 26FT BOX TRUCK (A69167)
2020 FREIGHTLINER...
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
CAT 320CL NEW Track Groups (A68134)
CAT 320CL NEW...
