Intermittent Failure
/ Intermittent Failure #1
JimBoy
Ossining, NY
John Deere 3720
Hi all. I have a JD3720 with a backhoe. The last two times I started the tractor, the left stabilizer would not raise. The lever would not move in that direction. After about 20 minutes, it would work. What is going on?
/ Intermittent Failure #2
water/ice in the system is a guess...
If that is the case, do I need to flush the entire hydraulic system?
/ Intermittent Failure #5
Most of the time it is water in the spring cup or in the linkage system, not in the hydraulics. Your system would have to be in BAD shape for a valve spool to freeze up. Personally I have never seen it. Almost all the time it is the detent or spring center cup on the back of the spool [opposite the linkage hook up] that has water in it. CJ
/ Intermittent Failure #6
I totally agree with this....
2018 CATERPILLAR 326FL EXCAVATOR (A65053)
2018 CATERPILLAR...
CATERPILLAR TL642D TELESCOPIC FORKLIFT (A62129)
CATERPILLAR TL642D...
New/Unused Wolverine 72in Quick Attach Ripper (A65583)
New/Unused...
UNVERFERTH HT25 HEADER CART (A63291)
UNVERFERTH HT25...
New/Unused AGT Industrial SDA-140T Track Loader (A65579)
New/Unused AGT...
Komatsu PC138USLC Excavator (A64047)
Komatsu PC138USLC...
