284 International
Veteran Member
- Joined
- Jun 28, 2010
- Messages
- 1,464
- Tractor
- International Harvester 284
In place of the chain drive what if you mounted a winch at the rear of the truck frame ans used it for controlled up/down?
That would work, but you would either need to run a pair of winches, or go to a single, center mounted lift arm.
if the winch were mounted at the front, going around a pulley to the lift arm would double the compression force seen by the bed or truck frame. I think swapping the cable(s) each time would be annoying. Winches dedicated to either or loading exclusively would make more sense to me.
