boatmoter
- Joined
- May 3, 2013
- Messages
- 257
- Location
- plant city florida
- Tractor
- john deere 212// john deere 320 // ford 2120 loader
run till it gets up to operating temp and shut it down, let it sit for around 5 min to build up a little pressure in the cooling system, then wiggle the fan blade towards the rear of engine then towards the front of engine. if you see leak then it's the water pump most likely out the weep holeWell, the CK2610 is leaking some coolant, but it's being a bit of a drama queen about it. It's leaking coolant from a bottom hose, but it's not an active leak. Running, the tractor isn't producing a leak I can see, but at some point after parking it's like it dumps a little out.
