insulation
/ insulation
I got a price for spray foam if I go 3" deep that's going to run me 4k! and 2" is 2,688 for the walls didn't ask about the roof. There are so many ways to insulate a pole barn I think I will go with 2" foam boards on the walls and 2" and put 1 1/2 on top of the 2" for 3 1/2 " in between the purling's with a 6 mil. plastic sheet for the vapor barrier.
/ insulation #22
Its going to be storage and a work shop so I will use 2" pink boards thru out, as far as building a ceiling I don't think I wanna spend more money on osb for the ceiling panels.
5/8" drywall is much cheaper then osb.
What's the size of your building ?
/ insulation #24
You would need around 32 12' 4'x8' 5/8" thick drywall for ceiling.
/ insulation
I don't think I really need a ceiling if by chance I want one I would have to take down all the knee braces on both walls!- a 30x40 like mine should be easy enough to heat.
I checked on line and 4x8 x5/8 is pretty cheap at Menards
/ insulation #26
You can work around the knee bracing. I did with a metal ceiling. If the trusses are on 8 foot centers you will have to add structure for any ceiling. More for drywall than metal.
/ insulation #28
I just did foam in a little barn I just built and I used the white 4x8 sheets from menards. I liked the idea of foam and I was eager to try it out. I insulated the walls and then the celing and when I finished the celing, I couldnt stand to be in the building because of the foam offgassing. It was so bad that when I walked in side even after i ket the door stand open for a day or two it would give me an instant headache. Its not a common experience but dont make the same mistake I did, a lot of work amd money for a building i cant use. Im going to tear all the faom out And maybe use bubble foil. However the pink (whatever brand that is) advertises no offgassing and environmentaly safe, just my 2 cents
/ insulation
its the pink board with the pic. of the pink panther willie
/ insulation #30
R value of pink and blue board is r3 per inch. Better than nothing but poly ISO will insulate better.
/ insulation #31
I did 24 inches of green fiber on the top of my metal liner panel mounted to the bottom of the trusses, I also studded my walls and did r-19 fiberglass. No reason for spray foam in this situation kinda overkill good stuff though.
/ insulation #32
I live in Alaska, so I have thought a lot about insulation. Fiberglass is not an insulation, but an air filter. I have remodeled houses and pulled out fiberglass batts which were dusty all the way through, because they had had convection cells in them during the winter, drawing dust through and drawing heat out. I recommend foam. Spray in is best, but the blue foam is good if you can seal it.
You need to have considerable separation between the underside of the roof and the top of the roof insulation. That pretty much requires a ceiling. Anything less is going to mean icicles and a leaky roof. The only way I would use spray foam on the underside of a roof would be on a Quonset hut, where there are no eaves for ice dams to form on. I gather that's not what you have. Your metal roof will have condensation underneath, so use foam above your ceiling, and lots of ventilation between top of insulation and bottom of roof.
On the house I am building in Interior Alaska, I used ICFs with extra foam on the outside, 8" of spray foam in the ceiling, and have about 20" minimum gap between the top of the insulation and the bottom of the roof deck.
/ insulation #33
seams were metal comes together (overlaps each other), holes at bottom of the walls, were walls meet roof, getting these places sealed up, so mice and other rodents do not get in, along with getting a seal proof from wind itself.
hard board insulation, plus spray foam, plus metal / foil insulation tape, can add up pretty quickly.
higher R value in ceiling vs walls, but making sure ya get all the cracks filled in and keep wind blowing in can be a big issue as well.
you may be limited to what you can use, when it comes to local building codes. some stuff may require an actual inside covering of some sort. while other full spray on coverings may not.
i do like the double sided foil hard board insulation. acts kinda like a radiant barrier to reflect heat back into building (during winter) and reflect heat out of shed during summer.
if you can afford it get highest R value you can. it makes a huge difference. with a pole barn, and having a gable ceiling, your roof is going to need get up there in R value. along with say some ceiling fans or blowers to move air around.
/ insulation #34
Lots suggesting sprayfoam. If you have deep pockets go for it. But for a polebarn I really don't think the cost is worth the benifit.
/ insulation
Spray foam is nice my house walls are all foamed up to the studs.Your right to much money for a pole barn One guy said I had a gable roof no regular roof with a 4 1/4 pitch.
/ insulation #36
Now I am not saying this would work for you but here is what I did. I have a 40x81 pole barn that I did not insulate when I bought it. It had enough condensation that it "rained" inside on occasion. I was fortunate to find enough used/offal rigid foam insulation that I insulated all the sidewalls an inch thick and the ceiling at about 3 inches for as I recall around $400 plus the hardware to attach it.
I have had no condensation problems since unless it is all above the insulation and I am unaware of it. If I had deep pockets I would have had spray foam but the cost estimate was many times what I had involved. Keep in mind also that I had a fair amount of labor involved but I enjoyed that.
Just what I did, not saying it is what you would want or need.
When I say the ceiling I mean underneath the entire roof, I do not have a ceiling that is horizontal like in a house.
2025 Kivel Quick Hitch Mini Skid Steer Attachment (A66734)
2025 Kivel Quick...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
2012 Chevrolet Impala Sedan. (A66738)
2012 Chevrolet...
PALLET OF DISCHARGE HOSES MISC SIZES (A67714)
PALLET OF...
2003 INTERNATIONAL MA025 SERVICE TRUCK (A66091)
2003 INTERNATIONAL...
WHEEL LOADER FORK ATTACHMENT (A67714)
WHEEL LOADER FORK...
