Insulating Pole Barn Ceiling
/ Insulating Pole Barn Ceiling
KennyG: thanks for the base detail ideas. I think I will just go with some exposed face of the 2X6 at the bottom between the posts. Probably like 3.5 or 4 inches in height and then just elevate the metal panel trim to that point. Later if I desire I can use a 1X4 or some other similar profile of base material to finish the detail. Heck I might even install a 4 inch vinyl cove base since is readily available here (cheap) at a local salvage outlet. I might even consider a 1 inch brick paver which they also stock.
My neighbor and I have about 10 rolls of 30# roof felt left over from two large roofing projects. I was planning on using a Typar building wrap on my outside wall furring. The cost of this material for my building is over 300 dollars. I know historically that felt has been used for wall wrap. Since I have the material does it make sense to just use it in lieu of the Typar wrap? If I need more felt material it is readily available at competitive prices.
Assuming this substitution makes sense, how would you suggest installing it? I suspect installing it vertically with staples over the furring makes sense and would cut down the number and length of joints. I would lap the material at all joints, I'm not sure the joints need to be sealed or need to be since the material is somewhat self-sealing.
There seems to be considerable hype concerning the commercial wall wrap materials in regards to their use and function especially the air infiltration part. I don't see how you can make hundreds of holes in the wrap material and really effectively address infiltration. The felt seems to be a more cost effective choice that seals itself better around the fasteners and sheds water better from the outside.
Any comments or concerns about what I am proposing, do you have a better idea?
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A59823)
2017 KALMAR OTTAWA...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57454)
New/Unused AGT...
2014 FORD F150 4X4 PICKUP TRUCK (A59906)
2014 FORD F150 4X4...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
