Instrument Panel Lights
/ Instrument Panel Lights #1
kamelgirgis
Texas
KUBOTTA B2400 , L4200 , Farmall super C
The instrument panel of my Kubota B2400 has no lights.
My forward pointing lights are mounted on the corners of the floor board in front of my feet.They work very well , but they don't light the instrument panel.Strong lights mounted on the ROPS above my head caused strong glaring reflection off the plastic insrument panel and and the back of my trifocals , causing eye strain.
Any ideas about adding "insrument panel lights"???
/ Instrument Panel Lights #2
I have seen those aftermarket lights that mount in, i think, a 1/2 hole and are designed just for that. They shine back down or to the side. You might just check around some of the larger parts stores and see what you can find.
/ Instrument Panel Lights #3
Unfortunately I dont' have your problem of not having an unlighted instrument panel, however on the glare on the trifocals, you might want to get the crizol or similar anti-scratch and anti-glare coating. My progressive lenses were real bad at night in having glare from lights. After I got the crizol the glare is almost eliminated.
Don
3146 (A63117)
3146 (A63117)
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A63118)
2023 New Holland...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
Fuel Barrel on Stand (A65640)
Fuel Barrel on...
HARGEE 18' BOGGIE AXLE METAL TRAILER (A63291)
HARGEE 18' BOGGIE...
